Question about Health & Beauty
My Interplak waterpik has lost water pressure. I changed nozzles, but it still doesn't have much pressure. It had intermittent good pressure over the last couple of weeks, but now there is only low pressure, no matter how high I dial it. I took the hose off the pump assembly and there is no obstruction. It doesn't leak anywhere.
SOURCE: gas pressure washer
I have the same problem with a Karcher 2400hh.
Go to: http://www.wmpcs.com/index.php?main_page=page&id=14
they have the best diagrams and answerss that I have found.
Posted on Jul 06, 2009
  • 583 Answers
SOURCE: excell vr2500 pressure washer ,no pressure
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Posted on Jul 30, 2009
  • 14036 Answers
SOURCE: subaru impreza 1993 power steering leak
YOU CANT USE A REGULAR FUEL LINE ON POWER STEERING AS A HIGH PRESSURE HOSE.BECAUSE POWER STEERING PRESSURE IS 1000 PSI.YOU HAVE TO BUY THE POWER STEERING HIGH PRESSURE HOSE IT HAS NUMBER OF PLIES MATERIAL WEAVES TO MAKE IT STRONG.IT WAS MADE FOR POWER STEERING HIGH PRESSURE.YOU DONT HAVE A BLOCKAGE .THE HIGH PRESSURE HOSE JUST WORE OUT.REPLACE IT .IT SHOULD FIX THE PROBLEM.
Posted on Sep 04, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
  • 10865 Answers
SOURCE: does not give a continous high pressure flow cuts in and out
Hi. Water flow may be restricted to the pressure washer.
Check that all hoses are free of kinks, leaks, or blockage. Make certain all hoses and fittings are connected properly. Make sure to open the faucet/spigot to full force. Set the spray wand to high pressure.
Clear any debris from the nozzle. If the nozzle has even a little bit of dirt in the tip, it may cause enough obstruction for the pressure washer to pulsate. If your pressure washer came with a nozzle cleaner, use it to clean the tip. If not, you can use a pin or paper clip to clear the nozzle tip of debris that may have become lodged in it.
If these have been checked and the washer is still fluctuating from high to low pressure there may be air trapped in the pump. To bleed the pump of any air, turn the machine off and disconnect the high pressure hose and trigger gun from your power washer. With only the garden hose connected to the machine, turn on your water source and allow water to run through the pump of the machine for 20 or 30 seconds. Turn off the water and connect the high pressure hose and trigger gun and try using the machine again.
Posted on Jul 31, 2010
Is the Waterpik Ultra Cordless Dental Water Jet WP450 good for sensitive gums?
The Waterpik Ultra Cordless Dental Water Jet WP450 has pushbutton dual-pressure control system with low for sensitive gums (as well as high for deep cleaning).
Apr 29, 2013 | Health & Beauty
Presure washer
Adjust the screw on the pressure regulator on the high pressure hose is one way The other is to check the nozzle for obstructions. The problem is that there is insufficient flow from the nozzle so the regulator valve is trying to cycle between cut off and working pressure.. The regulator is set at factory for a particular size nozzle and anything that alters that ratio will cause you problem. The screw on the regulator has some fine adjustment to allow for slight changes. Any impurities in the water supply will tend to block the nozzle affecting the regulator .
Apr 26, 2013 | Garden
Troy bilt pressure washer 2550 psi 6.25 hp. we borrowed from my brother and it doesn't have full pressure coming from the nozzle because there is water steadily coming out of the side from a sun shaped...
There is a valve installed to release water out of the system if water temp. rises to a level that may damage the pump. Water temp will rise when motor is running and you are not spraying water. This part is called a thermal valve. It can begin to leak water if worn out or debris under seat, however may not effect a lower pressure at the wand unless it leaks more water when you are spraying than when in bypass. You can see various thermal valves by searching on ebay with the key words :
"pressure washer thermal valve". Pressure is created at the tip of the wand. If the nozzle at the wand is worn or too large for the system, pressure will be reduced. You can check if the tip is correct by using a different tip that came with your system or using new of correct gpm as noted on the specs. of your system. Good luck
May 30, 2011 | Briggs & Stratton Prosumer 20324 Gas...
I have the Eco Rain showerhead and about half the nozzles are no longer putting out water. How can I clean them out?
Disassemble and soak it in a lime cleaning solution or vinegar. I have include a link below with more information for you. I hope this will solve your problem.
http://www.wikihow.com/Clean-a-Heavily-Clogged-Up-Shower-Head
Jun 16, 2010 | Water Pik WaterPik& Ecoflow Hand Held...
I have one turn handle in the shower. When I turn it to the right for cold wter, the cold water comes out fine - good pressure. When I turn it to the left to get some hot water, the water goes down to a...
Alot of newer shower controls have a tempering valve on them. You need to open up the front of the unit (hopefully you have your owners manual and adjust the inner workings) this should solve your problem
Jan 04, 2009 | Water Pik Waterpik& Elements& Handheld...
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Health & Beauty Logo
646 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
