Question about Electrolux Vacuums
Hello, My Electrolux Renaissance is about 12 years old. It worked great for years, but now it keeps turning itself off...about every 15 seconds or so. The bag was just changed recently, too. Is there an easy, (and cheap) fix or should I start shopping for a new one?? Thanks!
    Novelist:
  • 97 Answers
Odds are you have an obstruction somewhere. Check all of the hoses and the power head to ensure that there is nothing blocking your airflow.
Also note that if it keeps popping the front bag door open, that's usually indicative of either the bag being full or not being installed properly, which can give you the same results, so try taking the bag out and popping it back in just to make sure everything is aligned correctly.
-R
Posted on Aug 01, 2008
I have a renaissance cansiter vacuum. When I plug in the canis ter no hose attached, it does not come on like it shouldn't , however when I attached the hose and wand I turn it on it will start to ru
It is running properly if you are doing what you say you are.
It should NOT run without the hose and should with it plugged in if the electronics in the hose and vac are working properly. This was the major problem with the Renaissance Model and was only manufactured for a few years.
With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Dec 07, 2014 | Electrolux Vacuums
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
I cannoot find bags to fit my Little Lux Model # L673BA
You can find those bags at
http://www.totalvac.com/850-12.html
Fits all Electrolux canisters/tanks made after 1954, (except Lux 9000, Guardian, Epic 8000, Renaissance, Harmony or Oxygen models) Generic 12 pack of Electrolux vacuum bags.
Mar 01, 2011 | Electrolux Little Lux Bagged Handheld...
How do you replace the 'after filter' in the electrolux guardian?
1. Press latch and open the door that covers the tools.
2. Squeeze clips at front of tool tray, lift and remove.
3. Remove filter.
4 Replace filter.
5. Replace tool tray and close door..
Instructions can be found in the Renaissance manual, which you can download from the following site. Go to "older models", find Renaissance and click on it, then click "download". Instructions are on page 9. The Renaissance is basically the same model as the Guardian.
http://www.aerusvacuums.com/support/manuals/
Nov 28, 2010 | Electrolux Guardian Bagged Canister Vacuum
LUX RENAISSANCE WONT TURN ON. HOSE CONTROL BAG LIGHT IS ON
Could be the board in the handle but I found that a lot of the times the contacts where the handle meets the hose just need to be cleaned. It could also be a clogged hose but I'd say it's one of the other two.
Dec 04, 2009 | Electrolux Vacuums
Electrolux Renaissance canister
there are a couple situations to this issue. one is the bag that was replaced is a incorrect one and it is not meeting the switch for the bag pop circuit. some over the counter bags cause this issue. another problem could be the switch itself. or the bag door not being tight enoug to make contact with the bag.
Aug 07, 2008 | Electrolux Lux 5500 Canister Vacuum
Electolux renaissance
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576614
Generic problem for all Vacuums
Electrolux renaissance
Posted by maryannn2l on May 06, 2008
No power when I plug into outlet
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have 3 problems that I can see. You may have a bad electrical outlet, but I doubt it, the bad cordwinder cord or a short in the cordwinder itself, or a connection came loose in the motor section. If you need further assistance then contact your local vacuum cleaner dealer in your area or contact the Electrolux factory listed below. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Electrolux EL7055 just stopped
They aren't quality machines, they are made by Eureeka, not Electrolux. Aerus/ Electrolux is really the way to go!
Sep 27, 2007 | Electrolux EL7055A Bagless Canister Vacuum
Vacuums Logo
244 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
