Question about Prestige Remote Start
Prestige car starter just stopped working - Prestige Remote Start
  • 30 Answers
The first thing to check would be the batteries in the remote start control attached to your key ring.
Posted on Mar 11, 2011
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
My preinstalled prestige remote starter has worked twice at the dealers and i got it to work once. my question is do this combination sounds fimiliar for a chevy 1500. lock doors...lock door again, ho
If it is an add on remote starter, then you would use the factory remote to start it. If using the factory remote to start there are a couple of combinations to start it. Try lock, unlock,lock for Prestige/Pursuit models. If Directed models, try lock, lock or lock, lock, lock. If its a GM remote starter, press lock and then hold the remote starter button(circle with arrow.
Aug 03, 2012 | Prestige Appliances Vehicle Parts &...
I have a new prestige APS-57C remote starter installed in a 2009 Hyundai Santa Fe and I have a problem with the factory alarm going off every once and awhile. The majority of the time everything is fine,...
Maybe the installer did not hook up the remote starter unit to disarm the factory security system upon entry or remote-starting. Ask the installer to double check that part of the install as it would cause the factory security to trigger even though you unlocked the vehicle with the remote start unit remote.
Jan 25, 2011 | Prestige Remote Start
I have a honda pilot with the prestige car starter and the panic alarm keeps going off when I open the door. I can not get it to stop so it has to go through its 2 minute cycle. any ideas on how to get...
That is your factory alarm. I will assume that this Prestige unit is a remote starter with keyless entry...and you are using the Prestige unit to unlock the doors. Apparently, the unlock wire is connected but, the factory disarm is not. You can turn off your factory alarm by unlocking the vehicle with the key.
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
Prestige remote starter fell in bowl of water
Wasn't the unit hooked up already? You can't plug it back in? I'm still trying o picture the dropping into a BOWL? of water???
Give me the model and I can give you color codes, but if the wiring is still in tact you shouldn't need to rewire. Let me know and I'll help you out.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 28, 2009 | Prestige APS686T Remote Start and Keyless...
Do these work with pus button ignitio
Yes, the remote start can still operate your car, but I suggest not installing it yourself.. Take it to a reputable shop in your area! Push button start cars are different than regular key ignitions, so if you have no experience with remote starts, dont try it.
Dec 11, 2008 | Prestige Remote Start
Prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Dec 01, 2008 | Prestige Remote Start
Prestige Remote Start Logo
256 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
