Question about Haier HLH406BB 40 in. LCD HDTV
Loud pulsating noise when the t.v. is turned on with a black screen
  • 11,361 Answers
You may have bad power supply DC voltages, or it is turning on/off in cycling mode if it detects shorted circuits.
Please read my guides to get some understanding.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Mar 11, 2011
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Pulsating
If you select the Normal Cycle, twice during the cycleyou will hear the wash motor going on and off at amuch different cadence. The pump will pulse severaltimes, repeatedly turning on for less than a secondand off for 10 seconds. This allows it to drive soils off the filter and into the drain while using very littlewater. If, after selecting the Normal Cycle, you select either the Sanitize or Hi-Temp Wash options your dishwasher will understand that a stronger wash is needed and it will not use this pulsing routine
Jul 25, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Chorus emits a pulsating noise
Sounds to me like low-end gear. You honestly get what you pay for. If it happens to be high-end then you have either bad cables or just a bad effects processor. If you have on-board effects built into the amp, then get better equipment.
Hope this helps.
Aug 31, 2012 | Ibanez IBZ10A 10 WATT ACOUSTIC AMPLIFIER...
Black screen , loud alarm noise
The problem of your laptop is in the RAM just clean the RAM by wiping an eraser of the printer or a rubber. To remove the RAM open the back of your laptop where the RAM was inserted.
May 28, 2010 | Toshiba Satellite A100-S8111TD Notebook
No water , when running, loud pulsating noise
Usally when there is no water comming in it is the water inlet valve. First turn selector swith to see if it is only hot or cold water that is the problem. Take the hoses off the back of the washer and make sure that when you turn the water on that there is lots of water pressure comming out of the hoses. If ok. its probably the water inlet valve. There are two screws holding the valve from the back. Access the valve. Remove the fill hose from the valve. Remove the four wires off the valve and put on the new valve. Reinstall fill hose and install valve with two self taping screws you took out. Put your hoses back on and your ready to go.
Dec 22, 2009 | Kenmore Washing Machines
Noise from rear truck area of car similar to when top is being lo
usually the noise came from the differential in this circumstance.
Mar 22, 2009 | 2007 Aston Martin V8 Vantage Roadster...
LG top loader slapping noise in wash cycle
Its not the usual problems found on Lg machines. sounds like you have possibly one or more coins being picked up underneath the pulsator. To check, remove pulsator with screwdriver and check .Very possibly you have a bra cup spring caught between the two drums which make an akward sound.
Jan 27, 2009 | Washing Machines
Black Screen VERY loud noise
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Oct 14, 2007 | Samsung HLN5065W 50" Rear Projection...
Haier HLH406BB 40 in. LCD HDTV Logo
303 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
