Fujitsu Siemens SCALEO 600  PC Desktop
Problem for Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop
PC Re-Boots
By Welshboy59 on Jul 31, 2008
My midi tower will not boot when it is cold as it continiously re-boots. If I get the system to warm up sometimes it will boot and last about 10 minutes before it reboots.
I have enabled the POST and no faults are being reported and if I leave it run in the BIOS set up it will sit there all day. It is only when I start to load the OS that the problem exists.
Also if I boot from a CD for XP it will sit on the Welcome to Setup screen all day but if I try to repair or install it re-boots again. Could this be a memory problem ?
Same Problem
Dec 09, 2008
-   I have the same problem, in DOS the pc is running continously, byt in OS or trying to reinstall, it always reboots at the same point, when configuring the language settings or network card or similar, I have checked the hdd, and the memory w dos-software (memtest x86 and others) and it is running OK. could it be the mainboard?-   zuper_man
Solution #1
posted on Aug 21, 2009
Not Rated)
agent 10708
Rank: Master
Rating: 78%, 36 votes
it could. you want to download memtest86 from http://www.memtest86.com/memtest86-3.5.iso.zip
you need to download this and burn it to a cd using a ISO burning software. (basically means when you burn this to a cd, it will be able to boot from this disc on startup.) once you have the disc, put it in the tray and restart the computer having issues. on the splash screen for the motherboard, it should give you an option to pick your boot device, pick the cd/dvd rom drive and it should load the test if everything was done properly. after that, you will know if mem is bad or not
Was this helpful?
Yes
No
Popular Solutions for Fujitsu Siemens SCALEO 600 PC
Questions and Unsolved Problems for Fujitsu Siemens SCALEO 600 PC
Do you recommend Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop?
Answer
Answer
1tb Hitachi deskstar S/N R22RHXNX was dying on me for a while now, it wouldnt boot up in some cases,... (More)
Answer
I'm looking for fan 3-prong fan slot on the system board for an IBM Intellistation 6218-57U. Can... (More)
Answer
my lap top web cam is upside down how can i bring normal? help me .
Answer
I have a siemens fujitsu scaleo 600. I have miss placed my CD. Now my sounds are not working. I cant... (More)
Answer
My computer broke down, so I had to use the recovery cd, but I can't find my drivers&utility CD.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu Siemens SCALEO 600 PC...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
