Question about Sony Walkman NWZ-B142 MP3 Player
I have a Sony b152f which fell in water, while i try to shake it accidentally it is switched on ! Will it Work ?? What is the cost of the Battery ??
I hve mp3 sony nwz b142..just now i want to switch off my mp3 (after being charged)wit my pc it suddenly not switch off.i think it has been jammed.. what should i do to switch off the mp3??? plz hellppp meeee!!! thx
Posted on May 18, 2011
  • mrZac May 18, 2011
    thx 2 @tech86..i follow the advice finally i got mp3 on back...phewwww ...hahaha :)
  • Sony Master
  • 6,771 Answers
Unfortunately if the Walkman is not serviced within the hour of the accident it is already to late. When water enters it corrodes the ic pins and eventually works it's way in the ic casing and other critical parts causing short circuits, even if it worked! it will go into cascade failure in a matter hours, days, or weeks depending on the situation. I recommend not sinking any money into it because it will be wasted. Any electronic boards must be washed in rubbing alcohol and other parts that are important to get rid of any water residue, and the units have to be completely dis-assembled to have a fighting chance of success.
Posted on Mar 11, 2011
Testimonial: "ThankQ Boss, I would have wasted more money without your valuable suggestion !!!"
  • John Cunningham Mar 14, 2011
    Thank you for your kind words, John
It is not working
Posted on Aug 18, 2011
Fell my xperia s in salt water
This happened to my phone once, I just took it apart (the bits I could, sim card, battery, cover etc) then dried it for quite some time with a hairdrier (on a cool setting) then left it over night apart. Put it back together in the morning and it worked. I'm guessing there was still water/ moisture inside of it to stop it working..
Mar 04, 2013 | Sony Ericsson Sony Xperia S Lt 26i 32gb...
My Sony Camera fell in the sea water, can it still be fix? How?
Salt water damage is very bad for electronic devices, especially if the device was switched on at the time when it was dropped into salt water.
The cost of repair if you can get someone to repair it would most like be very expensive.
I would recommend you purchase a new camers, it most likely be a later and better model.
Dec 19, 2011 | Sony Cameras
Sony cybershot DS W80 is not switching since mother board is u/s. It fell in sea water. suspected problem in LCD also. spares are not available other than sony company servicing centres which is very...
The repair to any camera damaged by sea water will cost more than the cost of a new camera since everything must be replaced because salt water is corrosive. Add the replacement parts to the labor costs and you now have a repaired camera that cost more than a new one.
Apr 20, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
Need a driver for sony walkman NWZ B152F compatiable for Windows 2003
i need a free driver for sony walkman NWZ B152F
help me for download free driver pleas
i need a link for download
Jan 10, 2011 | Sony Walkman NWZ-B142 MP3 Player
I got an i-pod NWZ-B152F of sony.after connecting to P.C it starts charging but P.C does not recognise it.i want to transfer songs from my computer to i-pod.can you please help?
i got an i-pod NWZ-B152F of sony.after connecting to P.C it starts charging but P.C does not recognise it.i want to transfer songs from my computer to i-pod.can you please help?
Dec 29, 2010 | Sony Walkman NWZ-B142 MP3 Player
HI .. i have sony walkman ( NWZ-B152F) i keep recharging its battery because i dont know wheres the turn off button ... is there a turn off button for sony walkman NWZ-B152F?
How to turn on/off the power? To turn on the power Press the Play/Pause button to turn on the player so that the screen appears. ? If there is no operation on the player for a certain period of time while in the stop mode, the display turns off automatically and the player enters standby status.
Dec 24, 2010 | Sony Walkman NWZ-B142 MP3 Player
I have a sony ericsson k770i which fell into water accidentally, i immediately took out the battery and put it in sun light for some time then tried to switch it on, the two LEDs on the back side are...
Cell Phones and Water Do Not Mix Well.
If your phone is submerged in water for a SHORT period of time,
the proper way to attempt to save it, is to:
A) Remove the battery ASAP.
B) Open it up as much as possible.
C) Dry it out (Don't Put it in the Dryer!!!)
D) Clean all contacts with alcohol and qtip gently, allow to dry thouroughly for 24 hrs is best.
E) Make sure battery is dry as well.
F) then reassemble it and try your luck.
If it still doesn't work, it is done for.
From the sounds of it, you still have water in your phone, and if that's the case, you've probably already shorted it out/fried it. but try the steps above and MAYBE you got lucky.
Unfortunately, your warranty/insurance will not cover water damage!!!
but if you can "prove" that the phone is "defective" (the sticker under/near the battery is moisture-sensitive and is white when new, if it is colered (like pink or blue, that indicates you got it wet........then they willl know)......
HINT, HINT--- I boght a phone and it didn't have that sticker/sensor.......thus it was considered to be "defective" and they replaced it for free!......FYI.
There You Go, I wish you luck!
Please rate me and submit a testimonial of how helpful My Solutions are.
Thank You!
Mar 08, 2010 | Sony Ericsson K770 Cell Phone
My sony cybershot is fell on water and its not
listen to your service centre advise!
ITS DEAD and has no understanding of REINCARNATION or raising itself from the dead.
Unrepairable means just that, it cannot be repaired because the water would have shorted out most of the motherboard. The cost of any repairs if there were replacement parts ( which there are not) would exceed its value
Jul 06, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
What if it accidentally falls into water?
Here is a possible solution. No guarantees.
Remove the battery immediately. Take a vacuum and hold over the open battery compartment for about 15 minutes. Do the same on the front keypad for 10 minutes. (Use a vacuum to draw the moisture OUT. If you use a blow dryer you can force the moisture further into the unit.)
Place the entire open phone down into a bowl of uncooked rice for 24 hours. insert the battery and recharge. It's been know to work, but like I said..no guarantee. Good luck
Oct 20, 2008 | Motorola Mobility ROKR E6 Smartphone
Sony Walkman NWZ-B142  MP3 Player Logo
425 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
