Question about Amstron Toshiba Satellite A200-1AB Laptop AC Power Adapter (19V/6A 120Watts) by Amstron (Generic) AC Adapter
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the battery with charger plugged in it works without problem.I bought new battery couple a days ago thinking was battery problem.I 've tried also to uninstall the driver from devise manager and reinstall with different combinations,I ve tested my charger with voltmeter it is working fine as should......also I ve tested my power jack it is seemed fine ,no loose connections,I ve reflashed my BIOS too.Any suggestion what could be a problem
  • 135 Answers
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Posted on Mar 11, 2011
Toshiba satelite m70 wont turn on with battery charger plugged in
try taking out the battery, then with the charger plugged try toturn on the computer
Jan 16, 2013 | Toshiba Satellite A60 Notebook
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
I just bought a new laptop battery for my toshiba satelite A105, but the problem is the changing the battery, when the battery is low then i plug in the AC adapter the laptop keeps using the battery...
Make sure that the replacement battery is registering as a proper replacement and not a knock-off. This will sometimes cause them to act funny.
Check the power settings under Control Panel. It's a long shot, but there might be a weird setting in there.
Nov 10, 2012 | Toshiba Satelite A105-S4102 Notebook
Can't charge battery
Remove the battery and try if the PC turn on connecting to direct currrent.
If it turn on (whitout battery), the issue should be a connector problem or a damaged internal recargher.
Oct 19, 2009 | Toshiba Satellite A75-S2112: A75-S2112...
My toshiba s\atelite a135-s4527 wont turn on and
Could be the "resume" battery that has died - its an internal battery shrink wrapped in bright green plastic on tosh's normally - you might be able to get to it by unplugging stuff, battery, cd rom etc etc....unplug it and plug it back in again, if it comes alive again order another. I went on a toshiba laptop maintenance course years ago with a company that i worked for and that error that youre seeing was the fix....see if that works...
Aug 07, 2009 | Computers & Internet
Toshiba satelite A105 plugged in. No battery charging light
I suspect the system board. The slight ticking noise you hear would be the processor trying to start the hard drive but no being able to. Could be a hard drive failure but I very much doubt it
Dec 09, 2008 | Computers & Internet
Satelite L25-S1196
its better if you should take it to the technician and checked by him
Nov 28, 2008 | Toshiba Satellite L25-S119 Notebook
Satelite m115 s3094 will not work on AC adapter
here's a possible solution... the power supply pin that is on the laptop should be slightly bent to make a proper connection. do the same for the battery contacts. do not apply excessive pressure as the pins will break. good luck!
Sep 03, 2008 | Computers & Internet
Toshiba 5005-S504 satelite
Check power adapter and your power cord. Your battery is not charging....
Mar 15, 2008 | Toshiba Satellite 5005-S504 Notebook
Amstron Toshiba Satellite A200-1AB Laptop AC Power Adapter (19V/6A 120Watts) by Amstron (Generic) AC Adapter Logo
225 people viewed this question
Top Amstron Computers & Internet Experts
Computer Links
lapkitt
Level 1 Expert
Are you an Amstron Computer and Internet Expert? Answer questions, earn points and help others
