Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint wf430 continues to wash indefinitely. will not go on to rinse and spin
Had similar problem. Blocked filter and faulty pump, clean filter replaced pump approx £25. Took about 20 mins
Posted on Aug 01, 2008
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Wf430 stuck in wash cycle runs continuously No error codes, am able to stop it then pump out / spin Can you help please
try to check the pressure is not faulty, unclip the pastic tube and blow into it, should to clicks - that mean's it ok and then check plastic tube has no leaks and make sure it is firmly attached at both ends.
Sep 08, 2010 | Hotpoint WF430 Front Load Washer
Washing machine not rinsing and spinning wf440
I would suggest that you check and clean the pump filter.
This is to be found by removing the lower panel of washer, then remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint WF430 Front Load Washer
Wot is the best setting for a quick wash
If your washer is a Hotpoint WF430, then the quick wash programme is L.
This is a 30 minute, 30 degree wash.
Trust this is the information you are looking for.
Thankyou.
Jan 19, 2010 | Hotpoint WF430 Front Load Washer
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Hotpoint WF430 Noisy on Spin Cycle
Hi.
It could be loose balance weight, or worn drum bearings.
Remove belt and spin drum by hand from the inside, if you can hear a rumbling noise, or any noise, or it feels stiff to turn then the bearings have failed
If it is under 5 years old, then it should still be under warrenty provided you did not buy it from Comet or Currys.
If it is balance weight, you will be able to feel movement, there is one at top and one at bottom of m/c.
Nov 23, 2008 | Hotpoint WF430 Front Load Washer
Hight water level on rinse stage
hi there sounds like you may have a faulty pressure switch, this is located at the rear of the soap dispeser box under the lid.
May 25, 2008 | Hotpoint WF430 Front Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Washer doesn't stop
select a hot wash of some kind and check if the water heats. if not, problem could be heater or associated stat
Mar 30, 2007 | Hotpoint WF430 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
166 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
