Question about Whirlpool Duet GHW9150P Front Load Washer
The washer is flashing 5d and then changes to F-21. Will not complete the cycle. I unplugged the washer to let it reset but it still does the same thing.
  • 30 Answers
This problem could be with the supply or drain line. Shut off intake water valve to the Washer.
Unscrew the supply lines both hot and cold, check for any sediment in the screen, such as hard water deposits.
Make sure lines are not kinked. Once you have reattached the supply lines insure that the supply line valves are open fully.
Check that the drain line is not plugged or kinked in any way.
To do a reset, unplug the unit for a few minutes.
Please let me know if this has resolved your issue.
Posted on Mar 11, 2011
Error code 5d or f-21
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 16, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer machine will not complete a full wash it stops mid cycle and is flashing in the text box F 21. There is also water in bottom of the drum. What does F 21 mean and how do I fix it?
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
Thank you !!
Jul 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer stops in the middle of the cycle and displays F-1 and after I have to set it on the rinse / drain cycle to complete. Today for the first time it also displayed 5d at the end of the cycle.
5d or Sd means too much detergent was used. Try the following
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
F21 is flashing
This means the water is not draining out like it should. I solved this problem initially on my washer (my drain pipe was clogged), but now (about 4 months later), I have a flashing F21 and 5d, because of a clog some- where. I can drain and rinse (after this cycle, the door will unlock), and the tub spins, but I can't complete a cycle. Lots of debris has come out with rinse water, but I still seem to have a clog somewhere. I can complete a wash load by manually switching the settings.
Dec 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Code 5d comes on and it stops running
5d means the follow; possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. "Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool flashes 5d
try pushing pause/cancel twice and try again let me know what happens
Jan 17, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
