Question about Toshiba Televison & Video
The power light blinks 3 times. What does this mean?
  • 5 Answers
Toshiba Flat Panel Television how-to instructions, help and tips Three times so far, just the tv not the cable. Toshiba Flat Panel .... Timer light blinking red. TV will not turn on by power button on TV or using the ...
tv.manualsonline.com/.../toshiba/.../flat_panel.../product_problem toshiba.justanswer.com
Posted on Mar 11, 2011
I have a toshiba dlp tv what picture and sound not comihg and i chang lampto what same
Posted on Jan 18, 2014
3 Suggested Answers
circuitcity
  • 137 Answers
SOURCE: power button
This is a very simply fix. Your problem is you have a bad thermal fuse. This fuse can be found in the Lamp housing. You need to take the back off in order to fix this problem. Replacing the thermal is not hard, but you need to be a little handy. Part number 1-910-023-93 Average cost $9.00
Posted on Dec 07, 2007
  • 52 Answers
SOURCE: power supply board led green light blinks 3 times.
vscan is a voltage used to setup the picture for the panal. It goes to the y sus board. The problem is at the power supply or the y sus board. You can check these with a meter.
Posted on Aug 12, 2008
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Power light flashes 5 times and then ready flashes 3 times
Unfortunately that is 2 different errors... One being easily fixed. The 5 blinking power LED means its time to replace the Lamp, thats the easiest one to fix.
The blinking ready light means a "Fan 3 error". There is no reference on what that could be. It could be as simple as cleaning the air filter, or as complicated as replacing one of the fan units. You will need to contact Vivitek to know for sure:
http://www.vivitekusa.com/v_contact_support.asp
Attached you will find a chart for diagnosing the Power and Blinking Ready Lights:
Mar 10, 2011 | Vivitek D825MS Projector
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Red light blinks 5 times!!
C509 .47uF Mylar 250Volt. Replace this cap, this should restore power.
Jun 04, 2009 | Panasonic PT-53WX53 53" Rear Projection...
POWER LIGHT BLINKS 5 TIMES
That's the LA-3 LCD projection unit. 5 blinks on that model means a lamp driver error. You would need the service manual to diagnose exactly whats wrong with the system. I have included a link where you can get the entire 121 page service manual for your set if you would like it. It cost 15.99 and they will email it to you and provide free support to help you diagnose it. Here is the link if you would like the service manual.
http://servicemanuals.vstore.ca/
Feb 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Jan 25, 2008 | Toshiba CN36X81 TV
Televison & Video Logo
1,462 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
