Question about HP Compaq MP1800 Multimedia Projector
Compaq mp 1800
I have a purpleish hue on everything. The picture is otherwise OK. The color adjustment does nothing to correct this. It started all of a sudden
    Problem Solver:
  • 6 Answers
Most likely a bad cable. Try bending a little bit of the wire at a time and see if the color flickers back to normal, or you could just by another cable and see if that fixes it. Happens to a lot of the projectors I support.
Posted on Jul 31, 2008
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
The picture is so dark can't make out figures
It sounds that the back-light section has some fault with your TV. Otherwise, 30% brightness, 60 to 65% contrast, and 20 to 30% color settings should give you perfect picture.
Jun 06, 2013 | Digimate DGL20 Television
Both the picture and sound work when the TV is turned on, yet the picture is distorted like a double picture and has a yellow hue to it.
Sounds like you have a convergence problem. If you go into the setup menu of your TV, there should be some settings to adjust the red, green and blue hues and re-position them so each color matches up. If this does not work or if you don't have a menu, your TV *might* have a circuit board with several plastic screws on it. These adjust the picture and it's a very tedious task to re-align each hue correctly.
My projection TV is an older model from 1995, which is probably why it has this circuit board in place of a convergence menu built into the TV.
If adjusting the convergence still doesn't work, you might need to purchase a new convergence chip.
May 20, 2011 | Sony KP-51WS520 51" Rear Projection...
Sharp XR1S It projects the image on screen, use to show the correct color. last time the image was projected but in pink hues. is this an adjustment issue or is the lamp going or gone?
hi,
first of all check the tint setting on your projectors picture menu.
if not get the correct color then, your projector is a dlp projector that means it have a color wheel in side. if the synchronization of color wheel is not correct this problem can occur. there is a sensor for couting the rpm of color wheel. also have a black mark on the color wheels rotating portion. the sensor scene this black mark for making count. if there is any dust in that portion it will make difficult to the sensor making the counts. you have to remove the color wheel to clean the same.
i have added a video how to clean the color wheel . not the same projector.
ok
Feb 02, 2011 | Sharp XR-1S Multimedia Projector
My xerox Phaser 8560 is printing green? It was working fine but now All my pictures have a green hue. Why
I need to know something first. If you print a test page, an internal page, a confirmation page, menu page, etc, does the machine give you a green hue ?
Have you tried to shut the printer down and allow it to reboot? There is tec color correction on your print driver properties. You can try adjustments with that.
But first let me know if the internal prints are ok , then lets go from there.
Jan 18, 2010 | Xerox Phaser 8560DN Laser Printer
Color is gone, hue is greenish yellow otherwise everything else works fine i own a 50 inch Grand Wega Sony purchased in Dec 2005 lamp is new nothing in "menu" solves this problem
It sounds like the Optical Block is causing the problem. Due to the cost of the part, ( around 600.00), I would contact Sony at 1800-222-SONY and see if the would be willing to help out with the repair cost.
I hope this helps,
Skyassoc
Oct 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Just changed ink everything is purpleish pink esp3 kodak printe
Pink color usually indicates, color cartridge bad,
Try cleaning nozzles, head cleaner, alignment, calibration
Print off a test page,
If still bad, New cartridge, it's a bad one.
Hope this helps
Richard.
Apr 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Yellow tint in photoshop
Try adjusting the brightness on the monitor
Feb 27, 2009 | Adobe PhotoshopĀ® CS3 Extended Full Version...
Uneven Color on JVC Projection TV
hello i have a jvc 52" made in july 2004 replaced bulb twice under warranty plus replaced ballast board in 2005 replaced bulb dec 2008 my tv was before and after install having a blue hue reversed words
Sep 01, 2008 | JVC HD-52Z575 52" Rear Projection...
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
HP Compaq MP1800 Multimedia Projector Logo
201 people viewed this question
Ben Johnson
