Question about Philips Televison & Video
My new tv will not turn on - Philips Televison & Video
    Master:
  • 403 Answers
Return it
Posted on Mar 11, 2011
Panasonic tc50x5 no power
turned tv off to put on bigger stand turned of with remote and have tried diffent outlets but will not power on
Jan 23, 2013 | Panasonic TH-46PZ800U Plasma TV
Panasonic tv model tc-p42c2 remote is inop
It is a common thing that all the buttons of a universal remote control might not work, as it meant to be. Try an other code. If this too won't help you, there is no other way than buy a new original remote control for your Panasonic TV. You can buy in from the authorized service center for Panasonic at your town. Just give them the exact model number to your TV. They will provide you the original one.
Jul 20, 2012 | Panasonic TCP42C2 42 in TV
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
My LD320SSI bought 1/30/2011 powers off and will not turn back on it. When you try to power up the tv, it goes to standby blinks and then turns back off. It will do this for hour before we get it turned...
Return it where u bought it and get a new tv replacement,tv have power supply board issues.That the board where the tv power a/c cord plug into it.Or not possible trade in for another new tv,call Sylvania for warrenty service tv repair fix.
May 14, 2011 | Sylvania LC320SS9 32 in. LCD TV
I need the codes to install on a new tv
To search for the control codes that will work on your new TV, follow these steps:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 07, 2009 | Innovage Jumbo Remote Control
Parental lock
just disturb it
switch on and off on and off be fast
or switch on with program button pressed
it will unlock
Mar 20, 2009 | Philips Magnavox 13MT143S 13" TV
Power button Flashes, tv doesn't turn on
Buy a new one , not worth fixing. I have the same tv, with the same problem . It's getting old now and the price of a new one . It might cost $ 400-500 big ones to fix it . Thats half the price of a new flat screen , cheap model mind you . But I still think it's not worth it .
Nov 28, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Turned off
Greetings!
You have said that your TV is new, therefore it is underwarranty. Better not to remove or touch any parts of your TV that will cause more damage. Bring it to the center for check-up.
Thanks
Nov 05, 2008 | Sylvania 6727DF TV
How do i program my remote
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
Aug 25, 2008 | RCA DISH Network(r) 311 Satellite System
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
149 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
