No display in monitor screen only cpu fan is moving help me how to solve it
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Mar 11, 2011
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Feb 11, 2011 | ASUS M4A88T-M Motherboard & AMD Athlon II...
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
No Display, monitor won't come on.
hi try this or the site below
Monitor Problems:
THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
- Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician.
COMPUTER BOOTS, BUT DISPLAYS “JUNK” ON THE SCREEN
- It may be that the display card is defective. Try a different card. If it works the first card may be bad.
- Try the suspected bad card on another computer. If it displays the same thing it is conclusive that the card is bad.
DISPLAY IS DIM, OVERLY BRIGHT, OR BLURRY, OR UNPLEASANT.DISPLAY IS OFF CENTER. LEFT OR RIGHT SIDE OF MONITOR IS OBSCURED.
- Try adjusting the control knobs located on either the front or back of the monitor. It maybe necessary o open the monitors casing to get the proper adjustment controls. In this case be very careful because there are high voltages in the monitor.
THE VIDEO DISPLAY FADES AND BRIGHTENS, OR IS WARY.
- The voltage may be fluctuating due to so many appliances or electric devices on he same branch circuit.
- Turn off other appliances and peripherals, such as printers, external modem, refrigerator, microwave oven, transformer, etc. and see if that solves the problem. If the problem persists, try swapping out the display cards. If changing the monitor solved the problem, repair or replace the monitor.
IMAGE IS NOT STRAIGHT ACROSS THE SCREEN
- If the monitor is still under warranty, bring it back to the dealer for adjustment. If the you want to do it your self, bare in mind that this is potentially dangerous procedure because it must be done while he monitor is on and there is very high voltages around the picture tube.
WARNING: THIS IS A DANGEROUS PROCEDURE!!!
- Open the monitor casing and loosen the clamp holding he coils around he picture tube. You can loosen them (usually there’s a wing nut) and a rotate the coil assembly until the picture strengthens.
http://www.karbosguide.com/hardware/module6c.htm
Mar 30, 2009 | Dell Inspiron 1501 Notebook
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
try to clean your video card and ram using the eraser.
Mar 17, 2008 | ASUS P4VP-MX Motherboard
Monitor
Reset the Cmos battery,check the RAM,check the smps or check the motherboard ground, I think you problem will solve.
Feb 16, 2008 | Computers & Internet
LG 194wt
This is most likely not a problem with the monitor but rather a problem with the computer. do you hear the fans running in the computer? If so then the Power Supply seems to be working which would leave the most likely things are CPU or motherboard and the only way to determine which one it is would be to try the CPU on a different motherboard or try a different CPU in that motherboard.
If the fans do not run then the problem is most likely the Power Supply. The biggest problem here is that although what I have outlined is the most likely problems there are other things that could cause this and whether the fans are running or not it could still be the CPU motherboard or Power Supply. If you can I would check the voltages from the Power Supply or at least get a power supply tester to see what that shows and work from there.
Nov 13, 2007 | LG L1915S 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
