Question about Gateway M305CRV Notebook
Just installed 2 512 mb memory but when i turn the laptop on the fan turns on and the lights blink but it works fine with old memory. and others have upgraded memory to 2 gb when the max is 1 gb and theirs works fine. can i upgrade to 2 gb and how do i get my computer to work with the new memory i just boght
  • 35 Answers
Sound like you have two questions:
1) Why does my new memory not work?
2) Can I upgrade to 2 GB?
For Question #1, my thought is that maybe the new memory does not match up the laptops specifications. According to Gateway's website, "This notebook has two 200-pin industry standard DDR-SODIMM sockets that can accept 266 MHz DDR RAM memory module." Is the new memory 266 MHz? If not, that could be your problem and you should get the appropriate type of memory.
If the memory you purchased is 266 MHz, you probably have defective hardware and should seek a refund or replacement.
As for Question #2, you can try it but you may waste your money. If the manufacturer says the max memory allowed is 1 GB, it probably is true. I would only try it if you could get free, cheap or borrowed memory.
Posted on Mar 11, 2011
I just got this Dell Inspiron 1100 laptop used from Ebay that arrived on Thur Aug 15th. I installed my DDR memory and my 250gb ide hard drive. The laptop fired right up. And I installed XP Pro. ...
XP Pro! Now there*s your problem Mythbusters would say. Hence its going to become obsolete of security service after 4/2014, its not that MS is going to make it easy to install "new bastardo ones" into the system...
Aug 17, 2013 | Dell Inspiron 1100 Notebook
When i turned on switch dell vostro 230 it give no display and led colour is red
No Display, so does it seem like the computer booted up and is running except that the Display is black? Do you hear fans running, disk drive spinning, blinking lights or beeps?
I'm going to assume that in your case since you mentioned a red light that it is not booting up all the way. Therefore your problem is probably with the memory, the video card or some other motherboard issue.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 19, 2012 | Computers & Internet
My toshiba satellite l305d laptop does not boot,screen is blank,fan spins,hdd led does not blink,wlan led does not display,dvd rom light blinks,power led is on
If the power LED lights up it indicates that the laptop is getting power from the AC adapter. Most likely there is nothing wrong with the adapter but just in case test it with a voltmeter to make sure the output voltage is correct.
Also try this. Unplug the AC adapter, remove the battery and wait for 1-2 minutes. After that plug the AC adapter ans try starting the laptop again. Sometimes this trick helps.
It also could be a memory related problem. Try reseating the memory module, just remove it from the slot on the motherboard and install it back. Try installing the memory module into the other slot (if it's available). If you have two memory modules installed, try removing them one by one and start the laptop just with one memory module installed.
If the laptop starts fine with one memory module in both slots, but will not start with the second memory module in both slots, the second memory module is faulty. Replace the module.
If the laptop starts fine with both memory modules when they are installed in the slot A, but will not start with both memory modules installed in the slot B, the slot B is faulty and you'll have to replace the motherboard or use only one memory slot.
hopeyour problem solved
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
Sep 05, 2011 | Computers & Internet
I have a Toshiba Satellite A10-S129. It was working with 256 MB (2 x 128 MB). I wanted to upgrade it to 512 MB (2 x 256 MB). I bought 2 new 256 Modules and when changed it and turned on screen has...
If you get several beeps then there is a video problem. The video card uses shared RAM (part of the main RAM) and if the RAM is faulty the laptop won't boot up.
You might have incompatible RAM, try to use the same make and speed RAM as the original.
One of the RAM modules may be faulty.
Try installing one 256Mb RAM module then boot up the Toshiba, if it works the try the other RAM module.
Mar 20, 2011 | Toshiba Satellite A10-S129 Notebook
I have 2 of the same Hunter Douglass ceiling fans with double light kits in my living room. Yesterday one of them started blinking the lights constantly when I tried to turn on just the lower bowl light....
if problems with blinking lights, remove watt governor on inside of fan for the lights.its a black box,white to white wire and black to red wire. and wire it direct without watt governor or black box. this should fix the problem. the part # 98480-02 for watt governor. they installed watt governors on ceiling fans to reduce light wattage.
Sep 19, 2010 | Hunter Fan/Light Wall Mount Control 27186
Toshiba L45 S7409 can turn on and off, charge battery DVDROM resp
I sent my laptop to Toshiba and they said they removed the 3rd party memory I installed (although I tried this prior to shipping). I didn't reinstall the memory and now it works fine.
Mar 31, 2009 | Toshiba Satellite L45-S7409 Notebook PC
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Wont start up after ram upgrade
Try reseating the memory and if that doesn’t work, install the 512’s one at a time to see if one might be defective. If the laptop still won’t turn on, reinstall original memory and see if laptop powers on.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 20, 2008 | Dell Inspiron 1100 Notebook
How do I install more memory into my compaq armada 1700
You want to install memory on a 266 MHz PII?
A standard-configuration Armada 1700 has 32 MB of memory, and is expandable up to 160 MB.
Personally I don't recommend installing memory on this computer (I'd just buy a new one considering this one is pretty old), but if you still want to install memory complete the following steps:
  1. Remove the battery, floppy and disconnect the power supply
  2. Underneath the computer, there are several screws with arrows pointing to them. Remove these.
  3. There is one more screw in the center of the bottom shell. Remove this.
  4. Remove the laptop's bottom shell.
  5. Turn the laptop over and remove the keyboard.
  6. The memory is located on the left-hand portion of the laptop and is enclosed in a memory bay. Snap out the memory and install up to 160 MB SDRAM, assuming you can get your hands on it in the first place.
When finished, replace the keyboard and bottom shells, as well as the screws that you removed. Congratulations!
Jul 25, 2008 | Computers & Internet
Gateway M305CRV Notebook Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
