Question about Maytag Washing Machines
Maytag washer MAV5000AWW does not spin while motor is running
vest6
  • 196 Answers
SOURCE: maytag lse7800acw
The motor is faulty. Either the relay contacts are stuck or there is a shorted winding. Best to replace the motor.
Posted on Jan 14, 2008
jsrock516
  • 5911 Answers
SOURCE: Brake Squeal on Maytag MAV5000 AWW
Here's the same advice I gave another person with a similar problem to yours. The squealing can be caused by the brakes, or a worn snubber. It's usually a combination of BOTH. Since you may have to take the to disassemble the unit to repair, it only makes sense to replace the snubber as well. The part costs less than $10 in most cases.
The following link explains the problem you are having with your Maytag:
http://www.fixya.com/support/r387833-maytag_washer_squeaking_problem
It is common for the brakes on Maytag top loaders to wear and make noise, as well, as the snubber. There is a helpful tip that you can try to quieten the noise if it is the snubber by using corn starch. DO NOT oil it, or lubricate with any petroleum based products! This will ruin the unit and actually make the problem worse. NOTE: If the snubber is excessively worn, it was also cause vibration on the spin cycle.
If the brakes are worn, however, you can put a light film of oil on the brake pad. It is common for the pad to collect moisture in humid and damp climates and start to squeak against the brake stator. The brake pad consists of a rotor with a leather edge (pad). The leather can absorb moisture and begin to squeak against the brake stator. Oiling it slightly will get rid of the noise.
Confused? If you have questions, please let me know. I hope you find this information useful.
NOTE: There is a follow-up comment at the bottom of the link I provided from another user. The method this person used to release the tension on the brake can save you from having to purchase the brake release tool.
NOTE: You cannot access the brake pad or snubber by simply removing the front of the washer. You can SEE them, but you won't have full access until you disassemble the washer as outlined in the link I provided.
Posted on Feb 28, 2009
  • 686 Answers
SOURCE: Maytag washer SAV2655AWW - pulley wheel replacement
WHICH PULLEY FELL OFF YOU HAVE 3 OF THEM ONE IS A "IDLER PULLEY FOR DRIVE BELT" ANOTHER IS "PLASTIC HELIX, TRANSMISSION DRIVE PULLEY" AND LASTLY IS "PULLEY FOR TRANSMISSION DRIVE" GO TO www.repairclinic.com ENTER MODEL NUMBER AND SCROLL ALL THE WAY DOWN TO THE RED 100 CLICK IT AND LOOK FOR PARTS 550204, 889619, AND 889618. YOU MAY HAVE TO WORK ON THIS FROM THE BOTTOM TO GET TO THE PULLEY. IF YOU HAVE A MECHANICALLY INCLINED FRIEND, IMPLORE HIM OR HER TO HELP YOU UNLESS YOU CAN GET THE TUB OUT AND WORK YOUR WAY DOWN
Posted on Apr 18, 2009
landsend
  • 1066 Answers
SOURCE: maytag atlatis mav8551aww washer runs fine til spin mode then
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
  • 64 Answers
SOURCE: maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Posted on Jun 10, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Why my maytag washer does not spin
Before calling for service:
1. If you cannot hear the motor running check the lid switch. It's common for them to rust or break.
2. If the motor is running but no spin check the belt appearance and tension.
3. If 1 and 2 are okay go to service mode.
From Page 14 of the Service Manual;
Enter / Exit Service Mode To enter Service Mode press the Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps.
Follow the instructions in the service manual Maytag Washer FAV6800AWQ Repair Parts will give good images to find part locations.
Sep 13, 2014 | Maytag Neptune FAV6800AW Top Load Washer
I need maytag clothes washer model mav5000aww manuel
go to the web site "manualsonline" and download a free copy
Nov 21, 2010 | Washing Machines
How do I adjust the pump belt on Maytag washer ?
Depends on model.
For top load units with two belts under botton panel, tilt empty washer against a wall to allow access to belts and loosen the 3 pump mounting screws. See page: http://www.applianceaid.com/maywash_belt.html
Jan 07, 2010 | Maytag Atlantis MAV5000
Feb 24, 2009 | Maytag Dependable Care LAT9706
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
