Question about Frigidaire PLMV169DC Microwave Oven
When i turn the microwave on it has electrical short it is like there is something metal inside and everything still works what causes the electical flash
  • Frigidaire Master
  • 6,771 Answers
The interior of the microwave is insulated with an industrial white enamel paint to prevent the magnetron from arcing on the inside, some of the enamel has worn off exposing metal,or the magnetron is shorting, either way this is very unsafe to use and should be checked quickly, and left unplugged in the process.
Posted on Mar 11, 2011
My microwave model mv1526w when I press start it start to spark...What makes it spark and can I fix it?
It might be the appliance isn't properly grounded or it might be it is faulty or it might be there is something inside that is unsuitable.
Microwave ovens should not be operated with nothing inside and only suitable containers should be used to hold food for heating. Cups or plates with gold painted rims and metal containers and those containing metal are likely to cause a veritable electrical storm inside.
Mar 06, 2017 | Microwave Ovens
Why does my Microwave spark
That normally occurs when there is metal inside this is assuming it is coming from the inside of the cooking chamber. There should not be any metal in there as it causes a short and will burn up the magnatron in a retaliative short time.
Nov 18, 2014 | Microwave Ovens
I went to change a light bulb, light bulb pulled out of threads. Tried to remove threads and without turning power off and shorted something out. Underneath lights and fan will not work. The microwave...
I would say you have blown a fuse on the unit. As you now have found out, that's one of the reasons why you unplug any electrical equipment before working on them. You will have to take the outer cover off the microwave and locate where the fuse is. It is most likely on the back of the main PCB or possibly inside a plastic sleeve or mounting near where the cord enters the unit.
Feb 22, 2014 | GE JVM1440 Microwave Oven
Turned it on to heat food and make a loud noise , did not heat food and have electrical short ordor.
there is something metal inside that is causing this look for any screws or anything that may have been switch with a repair. what happens is the metal causes the microwaves to reflect back to the magnetron instead inside the food causing noises and sometimes sparks and odor. find the metal object remove it and this should solve your problem
Jan 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker microwave JVM1640sj03. It makes a popping noise as the table turns when I have food in it. What can I do to fix this and why is it happening. Many thanks.
theres something metal inside the microwave look for a screw or something that may have been placed in there during a repair. metal causes the microwaves to reflect back to the magnetron creating the popping noise you hear.
I have a Ge microwave model#je1860bh002 when i turn it on sparks acure after 5-10 secounds from inside a plastic cover on top of the microwave along with an electrical smell.
Behind this cover is usually a small metal blade fan that causes downdraught to circulate the air and electrons. It sound like it has a short circuit and should not be used. FIRE can be the result of persisting in turning it on. It should be repaired Replacement part is about $55 plus fitting so around $130 should be average.
Please rate my help++++Thanks for using FIXYA
May 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shorted out when metal grease filter contacted inside
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Jun 29, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Limited heat power
It sounds like the transformer is shorting out on you but is not completely shorted.It will be shorting out on the output side of the transformer.this will give you a lower output level,and will cause the microwaves to be weaker.(less turns of wire in the secondary of the transformer).The short will probably get worse.Simply replacing the transformer should cure the microwave.
Jun 23, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave smells of electrical fire
The magnetron inside the microwave is starting to short out to ground. This happens after use there are small minute cracks on the body of the magnetron and those small cracks are big enough for 15,000 volts and up to 30,000 volts to leak through and arc to ground. It is not a small short but a big one. Replace the magnetron before it burns holes inside your microwave. Replacing the magnetron if you can find it locally or through the internet is pretty straightforward. Unplug the microwave and take the cover off about 6 screws. On the same side as the control panel and right behind it you will find the microwave on top. It is held in place with only three to four big screws. It will have about 4 wires with terminals on them that plug into a couple of places one being the large capacitor that stores all the voltage and discharges it through the magnetron. Take the terminals off and I always recommend with some needle nose pliers with insulated handles. There is nothing to unsolder and to solder. Its like replacing the battery in your car or the electronic module. Take care and good luck.
Jan 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The unit made a pop noise and started smoking and smelled like burning rubber. Is the unit done?
I WOULD SAY SO! Most likely the power inverter board shorted out.
Sounds like perhaps someone put something with metal inside the unit without knowing and turned it on. Doing this tends to overheat the power inverter board causing a short in the system.
Be safe than sorry, replace the unit with a new one for around $100US. Lowes Home Improvement centers have some that are very inexpensive and are available in brushed stainless steel to match most kitchens.
Cheers,
Keith
Jan 02, 2009 | Sharp R-1492 Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
41 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
