Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Will not spray water on floor and will not clean
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
If your not getting your cleaner to function as it should, the first thing I would check is whether or not the power plug hasn't come loose from the outlet. Even the slightest bit of looseness will not make the electrical connection, and sometimes, even if you get the plug in correctly, it manages to work itself loose.
Secondly, I would check each connection that's actually on the cleaner; such as making sure every hose and tank has made it's connection and is seated right where it should be. You may hear a slight "snap" when you place the tank in the right place.
If your getting air into the lines because something isn't locked in right, this could easily cause the non-function problem.
Sometimes, I have had to re-seat my water holding tank several times before it will sit in there right. There can also be a hose or something inside the unit that is getting in the way of it fitting in there too. Look inside before you connect it to be sure nothing is getting in the way.
Also be sure you haven't filled the tank over the fill line. With these machines, you must follow every instruction carefully or they will give you problems.
I hope this helps you get your machine cleaning again for you.
It should...providing your getting power to the machine and you hear the motor running.
If not, you may have to call the manufacturer and ask them for help or to send you a new manual so you can figure it out that way.
Good Luck.
Posted on Mar 11, 2011
Steam cleaner doesnt spray water anymore
Hello, this is Ava with Think Crucial.
Check to ensure there is a full tank of Bissell Hard Floor Solutions and water. - Make sure the clean water tank is inserted properly by removing the tank and re-inserting it. Ensure the gasket is attached to the water tank and did not fall into the machine. Reattach this gasket if necessary. - Check the valve on the bottom of the clean water tank. The water should come out of the X-valve when pressed. If the valve is blocked, soak the cap and insert in hot tap water until the blockage clears. Check the handle to ensure it is installed properly. Remove the handle and re-attach, making sure the handle is pushed down all the way. If you need to re-install the handle, remove the solution tank and lift the tab as you lift the handle. Check to ensure the solution tube is inserted properly into the floor nozzle. Clean the spray tips by bending a paper clip and inserting this into the spray tips to clean. If you continue to experience no spray, you may need to call Bissel at 1-800-237-7691 for further assistance.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 14, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
How to trouble shoot and repair at home Bissell proheat 2X water will not spray from floor nozzel ?
Check your User's Guide. Cleaning the filters may do the trick. Contact Bissell Consumer Care at 1-800-237-7691
Sep 17, 2014 | Bissell Vacuums
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Will spray from handtool but not from brush floor
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! e
Sep 05, 2009 | Bissell 1699 ProHeat Clear View Upright...
I am also having the same problem - it will not dispense the cleaning fluid - it is more work trying to get the thing to work than it is actually cleaning the floor.
I just took the dispenser out and splashed the mixed water and cleaning solution on the floor, it works well, but I'd rather use a good spray bottle on my next floor cause the splashed can cause spots, unless the floor is already wet. In addition this floor mate is slow if compared to a spray bottle and a sponge on your bottom foot, moping and sliding your foot over stains, and mopping up till clean and streak free. Furthermore, I used Murpys oil instead, its works good Im happy, and tired this job requires constant cleaning and rinsing of your mop bucket, with a one man team, alot of furniture and a piano its alot of work, but worth it at the end, later, going for starbucks for that pick me up.
Jun 07, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
47 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
