Question about Panasonic Cameras
When I turn my camera on, it tells me there is a memory card error. I have put in several other memory cards and the same error still comes up when I turn on the camera.
    Guru:
  • 166 Answers
Check on the web site to see if there is a firmware update for your camera. You didnt state if the original card that came with the camera still works or if these are new cards. Some cameras can't use the newer cards so SD and SDHC are not the same and in some cameras are not compatable.
Posted on Mar 11, 2011
SOURCE: panasonic fz 18
i suggest you first try another card to check if the card or the camera is faulty. if it is the canera then it could be the sd card slot that is faulty. this will have to be checked by a qualified panasonic tech.
Posted on Jun 26, 2008
t00nz
  • 4738 Answers
SOURCE: S400 memory card error
The internal BIOS battery has run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Posted on Feb 22, 2009
thedayos
  • 57 Answers
SOURCE: Camera won't accept memory cards
The card may have to be "formatted" first.
Look at This Link Here to see how it's done
http://www.worldstart.com/tips/tips.php/958
Posted on May 12, 2009
  • 11967 Answers
SOURCE: memory card failure in camera
Your memory card needs a permanent home. Trading it between cameras is corrupting it. If there are pics on it, use a card reader to download them. Then choose a camera and format the card in that camera.
Posted on Feb 06, 2010
Obertelli
  • 3006 Answers
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Posted on Oct 06, 2010
This card cannot be used
Hello Harry, Tell me what message does the camera display ? Error reading ? needs format ? card protected ? ETC.
Jan 25, 2013 | Nikon Coolpix 2500 Digital Camera
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
I keep getting "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here.
Aug 24, 2011 | Canon PowerShot SD960 IS Digital Camera
99 error, CF memory card was removed to download pix. put CF card back in camera, but now get error message. removed battery and card several times, including replacing with another card. still get same...
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
Feb 13, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
Memory error
Have you formatted the card in the camera before trying to use it? (download any pictures still on the card using a card reader if necessary).
Aug 14, 2009 | Olympus Stylus 820 Digital Camera
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
SanDisk 1GB Impact
r u unable to copy d pics........???
tell me den i will give u soln
di tpe of error comes when memory card gets full....n dere is no space for more pics....
if u r able to copy d pics den copy it and format ur card
u can format it wid camera or by using external card reader...
Jun 18, 2008 | Kingston 1GB Secure Digital Memory Card
Format error
Before buying a new memory card, try to use your card in another camera. When you say you tried to format it through a card readr, do you mean that the card reader was connected to your PC?
Aug 19, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Camera not turning on
The Same thing just happened to mine said my card wasn't formatted, tried several card with no luck, the tell me too much money to have looked at $150 min they say buy a new camera. Always get extended warranty for 2-3 years the 49.95 is worth it in the long run.
Aug 16, 2007 | Pentax Optio 33L Digital Camera
Cameras Logo
32 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
