Computer wont connect to internet says turn on wireless internet button cannot find this please help
    Novelist:
  • 134 Answers
The wireless button is usually either above the keyboard, or is in the form of a "latch" on one of the sides. You didn't specify the model of your computer, so we can't tell you specifically where to find it. I can only tell you from experience where the manufacturers usually put it.
Posted on Mar 11, 2011
Can't connect to wireless internet anymore device
Please install the latest wireless adapter card driver and then configure it to your wireless router.
Dec 26, 2009 | Compaq Network adapter
Where is on switch for wifi button??
a lot of computers, like myne for instance, use a proram either natve to the computer like wndows, or something like intel PROSET wireless. i would recommend doing a computer search for these or other programs like these.
Nov 13, 2009 | Gateway 400SD4 Notebook
How are you doing. i have a house computer and my daughter brought over her laptop and wanted to go online but since her wireless button on her laptop is broke we wanted to just hook her laptop up to my...
if wireless wont work, do wired internet connection. buy a UTP wire with RJ-45 attach to it. plug end of rj-45 to your modem and the other end to the laptop. and setup the internet connection.
Nov 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Lights wont turn off even if netwrk wires are unplugged..
You'll have to hold your reset button down for atleast 10 seconds, or even more, then you'll have to reconfigure you entire connnection at address 192.168.2.1.
However before doing that, try and power down the whole unit for a minute or so and power it back up, then go to you computer's wireless connection and renew your IP address [that's if you have automatically assigned addresses]. otherwise you might have to check that you router and computer are operating on the same page [ by this I mean, if your router is assigning automatic IP, make sure your computer is not set to use a static IP, In my years of network, this has always been problem I have experienced on some routers]
Jun 21, 2009 | Belkin (F5D72304F5D7000) Router
I CAN NOT CONNECT TO THE INTERNET ..using Linksy wireless remote
the wireless card installed to your computer is working..as you said you can view all wireless networks...your computer is good too...the only issue is you cant connect to the wireless router...
turn off and unplug the power cable of the Modem
turn off and unplug the power cable the router
wait for 30 seconds
plug in and turn on the modem, wait for all the light turn to solid green ( no blinking lights )
then power on the router
if you saw the wireless icon light turn solid...
go to your computer...right click the wireless icon...select repair
if this doesnt work....reset your internet router by press and hold the reset button behind the router near the power plug (atleast 15 sec)
then connect your PC..the wireless network dont have the WEP key anymore because of the reset..you can reconfigure and put back the WEP key when you get connected.
Mar 16, 2009 | E-Machines (T2958) PC Desktop
Connection problems...
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a DSL connection that does not require a login, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection that requires a login, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Jul 25, 2008 | NetGear WGR614 Wireless Router
Trouble with wireless card
Something has gone wrong with your internet home connection--obviously nothing is the matter with your wireless connectivity hardware. You should reconfigure your home wireless connection. Follow the directions in Vista or XP help to set up a new home wireless connection. There are various ways to do this, such as through a router. If you have a home wireless router, be sure to set it for WEP incryption, or your neighbors will be able to get on your internet free.
Apr 24, 2008 | CMB T43 750 Notebook
The other computer wont log on to the internet
hi, even if it's connected properly if its not properly configured it still wont connect..so does it mean that other pc could connect? how bout your main pc does it work? which pc wont work? whats the o.s.? if you like i could help you i just need to know the full detail so i could help you diagnose it
Nov 28, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
Can't Connect to the Internet
Two things you can try before trying your browser/Internet connection:
1. Right click on the Wireless Network Connection Icon, click on Repair. Allow the computer time to repair its WiFi connection and some other settings;
2. Right click on the Wireless Network Connection Icon, click on Status. Click on properties button, select TCP/IP (Internet Protocol), click on Properties button, verify that the option "Obtain IP address automatically is ticked, OK, OK.
3. In your browsers, verify/modify settings:
In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings" (& pls make sure there is no check mark on the Proxy server), OK, Advance tab, check Use HTTP 1.1 through proxy connections.
In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Pls post back how things turned out or should you need additional information. Hope that this be of some help/idea.
Good luck and kind regards.
Nov 17, 2007 | D-Link Air DWL-122 802.11b Wireless...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
