Kenmore elite he5 is displaying code f35...can't find find what this code stands for
  • Washing Mach... Master
  • 2,605 Answers
Welcome to FixYa.
The F35 error code on most not all ...Whirlpool built front load washers ( this includes Kenmore, Amana, Maytag, Speed Queen and of course Whirlpool...but will vary slightly based on model number ) indicates the control has detected an analog pressure sensor error...please post the complete model number inside the door opening.
Whether the sensor is faulty or not remains to be seen, here's what to check first.
**Unplug the washer from the wall before servicing...safety first**
This error "F35", can be caused by the air pressure tube between the bottom of the washer tub and the analog pressure sensor, examine by removing the top and back panels and inspect the hose and dome, i.e.
If you find a cut/torn hose or loose connection in tube, then this is the likely cause the error. If it however appears okay, then you will likely need to replace the analog pressure sensor, i.e.
kenmore elite he5 is displaying - macmarkus_368.jpgi.fixya.net/uploads/images/macmarkus_368.jpg" alt="macmarkus_368.jpg" class="h_mi" />
As I alluded to though, make sure the hose is clear and not cut and the air-dome at the tub isn't plugged and if not you'll have to replace the switch.
Let me know how you make out and I'll help further in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Mar 11, 2011
Code F35 on Kenmore Elite HE5t front loader washer.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
I have kenmore elite HE5 front loading washing machine. it keeps flashing F35 during cycle and there is no help in the manual.
Nov 22, 2009 | Kenmore Elite 45986 Front Load Washer
Has code F35
I just got the same error code F35 and sometimes it says SUD. Help pls Kenmore HE5 Steam Washer.
Nov 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore he5 front loading washer. It
Jul 09, 2009 | Kenmore Washing Machines
My washer is a he5 and display a code of F35 do you know what is that
Jun 29, 2009 | Kenmore Washing Machines
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
May 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore He5 dryer, a service code f22
just remember error codes are always going to be stored on every machine ,, shoukd not have a problem ,, but does it work
Nov 29, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
308 people viewed this question
Top Washing Machines Experts
