Hello my moniter is an ACER X193w+ and when ever i play a game like Starcraft 2 it freezes up and says no signal. It is not the cable because i bought 5 of them and it does the same thing if it is my graphics card i have a HD Radeon 4770
    Sergeant:
    Champion:
  • 205 Answers
Sounds like your video card may be overheating. Try cleaning the cooling fan and make sure there are no obstructions to the airflow. Also you could try updating to the latest drivers. Click below:
AMD DRIVERS
On the far right side you will see the "Download Drivers" section
Selet desktop graphics from the compponent category drop down menu
Select Radeon HD series from the product line drop down menu
Select Radeon HD 4xxx Series PCIe from the model drop down menu
Select your operating system from the drop down menu
Hope this helps.
Zeppelinx12
Posted on Mar 11, 2011
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
Acer x193w Monitor won't come on flashes blue light you see word "Acer" it goes to flashing Yellow light and keeps repeating that.
you disconnect the monitor from PC
& see: it will show no signal or check signal cable. that means the monitor is OK problem is in PC. may be you PC is not booting properly. if monitor does not come on there may be fault in the main board of your monitor.
Oct 13, 2011 | Acer X193W LCD Monitor
I have an Asus X193W Moniter, and a fairly highend hyperthreading computer with Windows XP on it, (going to 7 soon) a GeForce 7600 3D graphics card, I plugged my Acer moniter into it and be damned if I do...
PROBLEM:
Weird colors
SOLUTION
that problem its a hardware failure, so you can't do much with drivers and softwares.
that happens usually when some filters (electronic component) fail so y best advice is take the monitor to a shop for proper fix
Aug 24, 2010 | Acer X193W LCD Monitor
No signal on computer moniter
1. Check your cable
2. check your cable pins make sure there not bent.
3. Check your video card make sure its putting out the correct resolution for the monitor.
No signal is just what it is. You may have a bad cable,bent pin or video card is not operational.
Things you can try.
Hook it up to a diffrent computer
Check the pins on the cable.
Worse case would be the little board inside where the connector is could be bad.
Thanks I hope this helps
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 07, 2009 | Acer AL1715 17" LCD Monitor
Acer X193W not getting any signal when connected to 8600GT by DVI
If you know the cable and the place it was before
replace it and reboot the dude (Ps if you dont have the referce and instructions for the take a polaroid
Oct 19, 2009 | Acer X193W LCD Monitor
"No signal" msg on new Acer X193W LCD Monitor with Vista 64-bit
this should be easy...go to your desktop...right click on it and choose "personalize" it will open up a window. on the bottom it will say display settings...click on it...at the top right it should say "identify monitors" click on that...if that dosent work.click on the monitor that has a 2 on it and it will ask you if you want to add a monitor...it should work
if not, post a comment and i will check back with you
Jun 21, 2009 | Acer X193W LCD Monitor
Problem installing StarCraft Battle chest
Hey.
1. Switch off your antivirus software.
2. Locate the folder(s) mentioned in error message, click with right mouse button on them and then untick "Read only" checkbox (choose second option in next window).
It works fine for me under Win XP (SP3)
Feb 26, 2009 | Blizzard Entertainment StarCraft Battle...
Rapid shuddering of icons, pix on Acer X193W monitor (10 mo. old)
in very first you have to check the pc with another display monitor
if display problem still available check the graphic card and video driver. remove the driver and reboot. check display resolution and refresh rate
Apr 12, 2017 | Acer X193W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
