Question about Kenmore Humidifiers
How much water and where do I put it I don't have a manual.
    Brigadier General:
  • 4,736 Answers
Kenmore is a Sears brand. If you have the Model Number, go to http://www.searspartsdirect.com/partsdirect/brands/Kenmore-Parts and you can search for and download the Owners Manual.
Posted on Mar 11, 2011
Bought this last year and don't have the manual. Can't remember how to fill the removable water chamber.
I would call or write to the warranty company: BW Consumer Services, POBox 8134, Elburn, IL 60119. 1-877-365-6274 and ask for the Walgreens Ultrasonic Humidifier 2055 user's manual. That is the information spelled out in the original users manual that come with the product.
Oct 18, 2011 | Walgreens Cool Mist Humidifier Humidifier
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Holmes Products HM500-UC 1 Gallon...
I HAVE A vICKS VAPORSIOR AND HAVENT USED IT VERY OFTER THERES no STEAM COMMING OUT EVER I USE COLD WATER DON'T FILL ABOVE THE FILL LINE I ALSO CLEANED IT REALLY GOOD WITH CLOROX. aNY SUGGESTIONS???
The unit may simply has a calcium scale build up and it's blocking the water passage. To clean it, empty in water remaining in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank. Allow it to soak for at least one hour, then turn the unit ON. Place you hand in front of the misting nozzle to see if it's working. If you don't feel any mist, turn the unit OFF and allow it sit over night. If you do feel mist, allow it to run until the tank is 3/4's empty Turn the unit OFF, pour out the remaining solution and refill with Bottled Distilled Water. Run the humidifier until it's empty. This will flush the system entirely. In the future, I would recommend you use Bottled Distilled Water, instead of Tap Water. If you do, you won't have to descale the unit any more.
Hope this helped you, please let me know. Thanks.
May 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
It ran out of water and the red light came on and now it won't work anymore. i put in new water, but the red light won't turn off. Any way to fix it?
Probably the float. The manual has instructions for fixing it: http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
Jun 12, 2010 | Crane Penguin 1 Gallon Humidifier
Toilet refills and water stops running. a couple seconds later get the sound of air which continues. if I push black float down a bit it stops manually but when I let go continues??
It can be one of two things first you either have air in your watter line in this case let water run for a while and see if you get air if so let it run until it quits spitting or contact your water company for help.Second the diaphram is worn in the top of the valve in this case the whole valve will need to be replaced turn off water flush toilet put pan or bowl under water line at toilet remove water line at toilet .Unscrew the fitting and remove hose next remove the large plastic nut on the bottom of tank .Some water will leak out hence the bowl! remove valve replace wit new one line up in same direction it was removed put on new rubber washer supplied,Tighten plastic nut replace hose and tighten turn on water that should fix it!
Nov 11, 2009 | Humidifiers
Orifice clogs to Aprilaire 600
http://www.aprilaire.com/themes/aa/en/manuals/600a.pdf look at page thirteen in this manual there is allready a inline filter on the unit. hope this helps
Jan 06, 2009 | Aprilaire 600 Humidifier
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Humidifiers Logo
114 people viewed this question
Top Kenmore Humidifiers Experts
Mack Baxter
ftykjg
ftykjg
julian hayes
julian hayes
Level 1 Expert
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
