Question about Sport & Outdoor - Others
How do I adjust the draw length on my Reflex Buckskin bow? Also, can you adjust the draw weight? It says 50-60 on the limb.
3 Suggested Answers
  • 6 Answers
SOURCE: which draw lenghth module should i use for a 28
you can find that info on the martin web site.
Posted on Jun 03, 2009
SOURCE: I'd like to know how to adjust the draw length on
you can try this manual, It looks like it covers your cam.If you need anything else hollar.
http://www.beararcheryproducts.com/customer-service/manuals/archive/2004/compound-manual.pdf
kc9ogb
Posted on Aug 03, 2009
I need to find out what model my bow is. serial # 2307711
look inside the limb pockets or under the grip. most of my hoyt recurves were stamped under the riser grip. You'll find a set of #'s @ the base of the limbs but that's batch ID , draw weight , leanth. for just the bow limbs not the riser, ( talking recurve here) with a compound you'll prob. only find one set of #'s.
you will need a bow press to break down a compound.
good luck & good shooting
Dec 16, 2015 | Archery
Bear Compound bow. 60 draw. How much does each turn of the screw decrease the draw weight?
Have you tried this site:
http://shootingtime.com/bow-tech-basics/adjust-draw-weight/
Dec 27, 2014 | Bear Archery Encounter Compound Bow...
Draw weigth
there are allenhead bolts on each limb that connect them to the handle frame. tighten these bolts evenly (one turn on one side should be matched with one turn on the other) this will increase the draw weight you are pulling
Feb 16, 2013 | Martinn Threshold Bow Set 40-50Lb Right...
How do I adjust the draw on a Bear Warrior III Bow
look in the manual and you will see what number coinsides with which draw length. On each cam there is a module with numbers on them. You set these to adjust draw length.
Jan 12, 2013 | Bear Warrior 3 Compound Bow Kit
How do I adjust the draw weight on a barnett vortex lite junior bow
There are two bolts that hold the limbs onto the riser. Tighten them all the way tight or clockwise. This will ensure they are the same. Now you have to turn both bolts equal turns up to no more than 3 turns out. The looser the less weight. Never loosen more than 3 turns.
Dec 26, 2012 | Barnett Outdoors Barnett Vortex Lite Youth...
Why does the bow length need to match my draw length?
The bow length needs to match your draw length because the bow limb is designed to be used at a particular draw length range. For instance if you use a bow with limbs too long for your draw length, you won't be able to flex the limbs enough to make them efficient.
Aug 26, 2012 | Betsey Johnson Archery
What affect the arrow velocity?
The speed of an arrow depends on the draw weight of the bow, you own draw length, the limb material and the energy profile of the bow. The wind condition, the humidity and the rain slows down the arrow and the faster an arrow travels, the flatter the flight trajectory and less deviation from wind.
What's a Reflex bow?
A Reflex bow is a unique bow that has curved arms that turn away from the archer. The curves put the materials of the bow under greater pressure, allowing a fairly short bow to have a high draw weight and a long draw length. I personally own a Reflex bow of my own an had lots of other bows and for me it's the most powerful bow I've ever used, so you defiantly try this bow out.
Jul 30, 2012 | Archery
What's the best bow for beginners?
You can findlots quality bows in different prices, but the best bow I advise you to get,the bow I actually purchased myself, is the Parker Sidekick. This bow isdesigned for beginner archers as it comes in 18- to 28-inches of draw lengthadjustable at 0.5 inch increments. Draw weights are available from 20- to40-pounds and 40- to 60-pounds with a comfortable 80 percent let-off.
What is 'stacking'?
This isthe amount of increase in weight as the bow is drawn. It occurs in all bows,but can be intensified in three ways. First, the bow may be too short for thedraw length. A longer bow could help this problem. Second, the ratio offiberglass weight or thickness should also be increased. Third, the moreradical the limb design the more the stack will increase. This means that at agiven limb length the bow weight, a more pronounced recurve design, will stackmore at full draw. The use of multiple tapers in a limb can also causestacking.
Jul 09, 2012 | Archery
Sport & Outdoor - Others Logo
275 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
