Question about Dynex DX-SC5.1 Sound Card
The error says, "no audio output device is
  • Dynex Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Posted on Mar 11, 2011
NO AUDIO OUTPUT DEVICE IS INSTALLED ERROR
try out the trouble shooting steps outlined here, however the best option is to uninstall & reinstall the audio driver
(http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00833257&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3647018\)
Dec 04, 2011 | Computers & Internet
I have a Gateway MX6400 laptop. After I upgraded to Windows 7 from XP I lost the sound. Drivers are up-to-date and connfirmed. When I click on the speaker in the lower right corner I get, "No...
Look at the driver properties. I suspect a generic Microsoft driver has been installed and that driver doesn't work correctly. (Right click on the audio device from Device Manager and select Properties. Then check the Drivers tab. Look for the line with Driver Provider.)
I can't find a MX6400 listed on Gateway's driver site, http://www.gateway.com/gw/en/US/content/drivers-downloads . There are the MX6410 and MX6420 listed. Both of these have a Conexant audio driver for XP and Vista. The Vista driver may work under Windows 7. (Make sure to correctly select the 32-bit or 64-bit depending on your OS version.) Download the driver and try to manually install it. If that doesn't work, try a Conexant audio driver from another laptop brand that is for the correct version of Windows 7. (Just Google Conexant audio driver Windows 7.)
I hope this helps. If you have a problem, please let me know what your Device manager claims the manufacturer is on the HD audio device and the driver manufacturer listed in the Properties. Also add a comment if you see any error messages when trying to install a new audio driver.
Nov 21, 2017 | Gateway (6000161) Sound Card
I dont have any sound, I got a message bottom right corner when I click on speaker icon "No Audio Output Device is installed" I think I need drivers for X-220 speakers, I can't find them...
You don't need a driver for the speakers, but a driver for the sound card installed inside your computer. If the computer came with that sound card then you can find the proper driver from the manyfacturer website -> Support section.
Sound drivers need to be reinstalled sometimes after iTunes updates or video game installs.
Mar 02, 2011 | Logitech X-220 Computer Speakers
I need a sound card for my dell dimension 2350
you should have a integrated soundcard on your dell if it doesnt work I recommend a Dynex DX-SC51 or a Creative sound blaster live 5.1 botha re great cards for your computer
Dec 12, 2010 | Dell Dimension 2350 PC Desktop
How do i install audio output device
No Audio Output Device Installed
Some users have been experiencing problems with a "No Audio Output Device Installed" error when trying to play music, or when hovering the mouse over the speaker icon in the system tray. You may get a white X in a red circle to indicate this error.
Go to the device manager by pressing WINDOWS KEY + R to go to the run menu, and then run "devmgmt.msc".
From here, select your malfunctioning audio device(s) and make a note of the driver name. Then, right click on it and select Uninstall. This will remove the audio drivers from your system.
Once this is done, re-load the drivers for your sound card from the CD your manufacturer gave you with your PC or sound device. If you cannot find this, search for the driver on the manufacturers website using the driver name that has been written down. No Audio Output Device Installed
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
VISTA CAN`T SEEM TO FIND A DRIVER FOR MY DYNEX MODEL # DX-SC51, AND I`M NOT HAVING MUCH LUCK LOCATING IT...
I installed the DX-SC51 software speaker is working but MIC not working and I couldn't find the way to turn it on
Aug 23, 2008 | Dynex DX-SC5.1 Sound Card
Bad direct drivers.
Dear sir,
I ahve problem like My laptop is C700 series of compaq(C772TU) I ahve changed it OS from vista to XP and now there is no audio output whenever I try to play a song it gives msg like " Please installproper device or select another device in configuration Error code: 88780078"
please suggest me proper solution
Mar 22, 2008 | Computers & Internet
Dynex DX-SC5.1 Sound Card Logo
127 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
