The unit makes a humming sound but will not kick on to heat the house at all.
    President:
  • 1,273 Answers
Hi, W/D here.
A humming noise can indicate that the motor isn't getting the necessary starting kick to start up. This extra starting kick is supplied by the start capacitor.
This can also be a problem with the motor proper. The cheapest thing to try is to replace the start capacitor. It is a can looking device that will be located near the motor, and connected to the motor by two brown wires. Trip your breaker outside for the A/C, and trip the service disconnect in the A/C cabinet. Use insulated tools to remove the wires from the capacitor, and do not touch the terminals with bare fingers as a shock could result, even after the wires are disconnected.
Locate a local appliance parts supply company, and take your old capacitor with you to get a replacement. Capacitors and motors are matched, so it is important to get a replacement with the proper rating. Reconnect the new capacitor and try it out.
A capacitor will cost in the less than, but close to $20 range, and is worthy of a try, and will probably fix your problem. If it is the motor itself, a motor and matched capacitor will cost you around $110, or less, depending on the horsepower of the motor. Again, any local appliance parts supply house, or A/C supply will have the necessary parts, and it is not a hard job to do.
Best regards, --W/D--
Posted on Mar 11, 2011
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
I just bought my house. I have all electric baseboard heat. One of them has started to make this high pitch humming noise. I cant find anything to identify what type of heater it is, nor do I know how
Could be just an AC hum do to time and previous heating expansion/contraction altered it's characteristics.
You could [this is a crude way} just kick it to see if that stops the humming other then that completely dismantle it and reassemble it tightening the connections and support structure
I don't know what your heating/electric bill is $$$$ but my experience it's cheaper to heat with some other form of energy and in case of power outages you can heat your house using a generator where as electric heat you can not
Nov 13, 2014 | Heating & Cooling
Is it normal for the outdoor unit on my coleman h/p to make a surging humming noise? the fan does not run during this period, approx. temp. is 28 degrees F. the fan runs 30 seconds befor the unit...
Sounds like your unit is going into defrost mode. When this happens the fan in the outdoor unit shuts off so you get more heat in the outdoor unit to defrost the coils. The heatpump is basically in A/C mode during defrost and the electric heat strips will kick in so you don't feel a cold blast of air in the house.
Jan 03, 2011 | Heating & Cooling
A/C unit doesn't start all the time, makes a loud humming sound
mcdevito75 here, Sounds like the bearing in the fan motor is going out on you, Thses bearings are a sealed unit from the factory, check out any A/C repair shop in your area for repair.
Jun 23, 2010 | Maytag M7Y12F2A Air Conditioner
Loud humming noise
try using a spirit level to make sure unit is sitting square,the most common cause of noise.....(also make sure its not touching the wall....)
Apr 13, 2010 | Whirlpool ED2FHSS Side by Side...
Fan running constantly in the house
Check t-stat and make sure fan is set to "Auto", that might be why fan is running all the time, or it could be a fan relay that is stuck closed. It sounds like you A/C is over charged or you have a bad high pressure switch, this was a common problem with this manufacture especially in the heat mode.
Apr 24, 2009 | Ruud Central System Air Conditioner
Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Jan 22, 2009 | Heating & Cooling
We have a Roof Mounted RUDD Unit. Yesteday when I went to check the thermostat to see why the house was so cold I heard it making a humming sound. I turned the thermostate to 60 degrees then it stopped...
You need to check if you have full 220 voltage to unit sounds like one leg of your power is out. You have slow blow fuses on this so turn off the breaker that goes to unit and then pull fuses out and check each one. You can check at the place where the main power comes into unit if you don't mind checking electricity but take your volt ohm meter and check the two power leads on the contactor that is the first thing that the power is connected to. Let me know if that checks out Okay. ken
Dec 28, 2008 | Ruud UAMB Air Conditioner
Fan
Ifs its a small humming sound,then its the contactor pulling in. But if it a loud humming sound then its the compressor kicking in. and the fans not, try to take something long and turn the blades on the fan, if it takes off and run then your capacitor is shot or swollen at the top,which was cause by power surge. Take-off and replace with the same mfd. writings ,on the outside of can. Also check for blown fuses or tripped breaker . the fuses should be in the disconnect box on the wall, or the breaker in the breaker box.. Older house has fuses instead of a breaker box!
Sep 01, 2008 | Bryant Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
