Question about Refrigerators
How much does a 32 ft fema trailer weight - Refrigerators
Load bearing weight of 3mm aluminium 8 x 4 sheet ?
Depends on the alloy, the weakest alloy supports 1300 lb/in and of course it depends on the spacing of the support cross members.
Jan 31, 2017 | Cars & Trucks
Is their a fuse or switch to reset the refrigerator on a Fleetwood FEMA 2006 slideout trailer
if has outside access panel look inside possible fusible link bad wire to holder on back wall
Oct 15, 2016 | RVs
Maxim 20'7 boat with a cuddly cabin and a 120 horsepower Mercury force outboard engine. What is the weight of this boat?
if you cannot get the details from the manufacturer of the boat and it is not on the compliance plate that should be attached to the boat( plate shows length, max hp motor to be fitted , registered no of passengers possible ,weight etc ), the only thing left to do is to put it on a trailer that is big enough and have it weighed at a public weigh bridge /station
you will be expecting a weight in excess of 1.5 tons or 1500 kgs
most 20 ft boats run on a tri axle trailer because of the weight and length
Sep 17, 2016 | Boating
Weight with and without trailer please
weight the boat and trailer on a truck scale, then go back without the boat on the trailer and weight it. Sometimes you can find a base weight for the trailer on a manufacturers website.
Mar 27, 2015 | Boating
UchsI am looking for a manual for a 2006 Gulfstream Cavalier FEMA Trailer. I am not having any luck finding one. HELP!
Hi Martha,
is the header of your message in any shape or form connected to your question?
thanks
rene
Jun 08, 2011 | GPS
I just bought a fema trailer and its missing the ac remote i know its a CARRIER but unsure of model number can i use a walmount thermostat instead
yes, but when you take the cover off you will discover the name plate with the proper info to replace the remote, also your fema preparer might have placed the remote there as well. thank you and good luck
Feb 03, 2011 | Dometic Rooftop RV Air Conditioner
I have power to my fema trailer, and 12 volts to the fuse box, but my lights still won:t work Why?
some vehicles have fuses for veh lights and trailer lights in dif locations /some have relay boxes under back of veh lots of trouble shooting
Jun 18, 2010 | Electronics - Others
Towing capacity for an Isuzu I370 pickup
As listed in the owners manual.
Weight of the Trailer
How heavy can a trailer safely be?
It depends on how you plan to use your rig. For
example, speed, altitude, road grades, outside
temperature and how much your vehicle is used to
pull a trailer are all important. It can also depend
on any special equipment that you have on
your vehicle, and the amount of tongue weight the
vehicle can carry. See “Weight of the Trailer
Tongue” later in this section for more information.
Maximum trailer weight is calculated assuming
only the driver is in the tow vehicle and it has all
the required trailering equipment. The weight
of additional optional equipment, passengers and
cargo in the tow vehicle must be subtracted
from the maximum trailer weight.
The following charts show how much your trailer
can weigh, based upon your vehicle model
and options.
2WD Extended Cab Axle Ratio Maximum Trailer Weight GCWR*
Automatic Transmission,
2.9 L Engine 3.73 3,100 lbs (1 406 kg) 7,000 lbs (3 175 kg)
Manual Transmission,
2.9L Engine 3.73 2,100 lbs (952 kg) 6,000 lbs (2 721 kg)
4WD Crew Cab Axle Ratio Maximum Trailer Weight GCWR*
3.7L Engine 3.73 4,000 lbs (1 814 kg) 9,000 lbs (4 082 kg)
*The Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded
vehicle and trailer including any passengers, cargo, equipment and conversions. The GCWR for your
vehicle should not be exceeded.
Aug 26, 2009 | 2006 Isuzu I 370
Refrigerators Logo
473 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
