SOURCE: machine leaks at beginning of rinse cycle
have you checked the rubber seal round the door might be torn
SOURCE: Samsung Front Loader wf306law took off back panel
I found MayTag has a full report on this washer. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2/$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at samsungparts.com
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-10417A.aspx
SOURCE: Kenmore 90 washer won't drain
How do I operate it? which program should i use for regular laundry?
SOURCE: I am having a problem with my front load washer
I had this problem with mine a while ago and it wound up being a rubber seal inside the machine. I had to have the serice tech come and repair.
SOURCE: I have a two month old Samsung WF350 front load
I just received my Samsung WD 8804 front loader washing machine, and during the 3rd wash trial, I noticed the same problem of water trickling down from the base of the front door. I took a closer look and the problem is actually due to a cracked rubber seal, which can be seen through the glass door. I have informed the technician.
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump. Please get back to me if you have any other questions.
Kevin
