Back door won't close - Office Equipment & Supplies
  • reidam Mar 11, 2011
    What kind of printer is it? (Make/Model #)
  • 22 Answers
May be the sensor of the back door is not working. or may be the small piece of plastic in the back door (its work is to close the sensor) is broken
Posted on Mar 11, 2011
What do I need to do in order to get the back door on the passenger side to close? A tech from AAA said I needed a spring for the door latch?
if it won`t close look at the door latch mechanism. there should be two u shaped claws that close around the door striker plate pin, sometimes these get closed before the door is closed causing the door not to close and stay closed. if they are closed(claws) pull the door handle to open the door and take something and push the claws out(open) then close the door.
Jul 08, 2014 | 2000 Plymouth Neon
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Back door close lock
check 2 c if the door latch isnt alredy closed if it is pull handel and use screw driver 2 flip it back out
May 12, 2013 | Hyundai Entourage Cars & Trucks
take a philips screwdriver in between where the latch grabs the part of your car its is a circular area and release the latch at the same time pull down on the screwdriver and it will pull the latch back in the correct position to be able to agai n latch to the cars part of the latch to grab to
Dec 01, 2012 | 1994 Chevrolet Suburban
My Lexus RX 330 back power door won't stay open, it keeps closing.
check the switch at the door and the on the inside
Sep 26, 2012 | 2005 Lexus RX330
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Door on 95 geo metro 4 door won't close because the child proof lock in on and I can't get it to go off. Door won't stay shut. Any ideas how to fix this?
Your childproof lock have nothing to do with the latch not closing. It only makes it where you can not open the door from the inside. I would think you are in need of a new latch.
Feb 12, 2018 | Geo Metro Cars & Trucks
The drivers-side back door of my 1998 jeep cherokee won't close. The latch has turned too far and won't go back to it's open position so, unless there is some trick you can recommend, it will...
since the door is open,, hold the handle in the open position and try and move the little hook looking latch , it may have just moved into the closed position , if you can move it to the open position, then your home free
Jul 04, 2011 | 1998 Jeep Cherokee
you can check the lock on the door isnt in the closed position(would sound like banging noise)
with the inner door handle pulled see if you can flip the lock to open on door. lubing doors once in awhile will prevent this
Jun 17, 2011 | 1996 Oldsmobile Cutlass Ciera
37 people viewed this question
k24674
jasbo
jasbo
