Question about John Deere Garden
The flywheel is only cranking slowly at start up, engine won't fire. The lead to the starter motor and the starter motor heats up, smokes a little. I have checked the battery, replaced the starter solenoid and had a look at the starter motor (brushes, etc seem fine) I am now attempting to remove the flywheel but can't budge the nut on top??? model: john Deere ride-on-mower L100B serial: gxl100B016902
  • 718 Answers
If your unit has OHV engine you need to check the intake and exhaust valve gap. Call your local repair shop to get numbers and check this website out. Go to smalleng.com they have a video for just what you are looking for. Good Luck...
Posted on Mar 12, 2011
Testimonial: "Thank you, have since had v.similar feedback. I am on the case. Thanks again for your help!!"
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
2003 Lincoln Navigator starter grinding when starting
If you mean the starter grinds from time to time and won't crank the engine when it happens, the problem could be a bad spot on the flywheel and/or a faulty starter. The starter uses a magnet and bendix gear to push the starter gear into the flywheel. If the magnet or bendix is weak, the gear will not engage and can damage the teeth on the flywheel.
You need to have the starter removed and check the flywheel teeth for damage.
Aug 03, 2012 | 2003 Lincoln Navigator
Starter works fine but won't crank engine. the pick up has to be given a push first before it starts
If the starter is spinning when you try to start but doesn't spin the engine over then you most likely have teeth missing off the flywheel ring gear. The facts that you say you have to push it and then it starts means the flywheel position changes and the starter has good teeth on the flywheel to engage. To confirm this next time the engine won't crank over remove the starter and look inside at the flywheel for missing flywheel teeth.
Mar 13, 2012 | Ford Cars & Trucks
I have power to everything but the starter wont turn motor over and starts smoking i have changed the starter and the same thing keeps happening what could be causing this to happen?
This means that the starter is under a great TORQUE as it strains to turn the flywheel. Since the starter is a new piece the fault points to a jammed/tight engine. Also the starter pinion and flywheel meshing also need to be checked, in case there is a wearing of the flywheel. Finally the plugs can be remove and checked if the crank moves freely, if not there are issues within that needs closer attention.
Sep 28, 2011 | 2000 Oldsmobile Alero
My 2002 Toyota Camry won't start, I tried jump starting it, but the starter won't even turn over or crank.
well in this case it can be the starter. you need to check if you get power to the skinny wire on the starter wile you crank. if yes then it is the starter. in worst case if you drove the car with out oil or if it got over heat too much. engine could be locked.
Jun 27, 2011 | 2002 Toyota Camry
My Ford five hundred won...t turn over (crank)...the lights are on and when I turn the key I hear a ticking sound but it wont crank...what problem might I have
All indicates to a flat battery. If the lights work or the horn blows, that is no indication that the battery is still good. You need to use a hydrometer to test the electrolyte SG to check if the battery is at full charge.
Apr 12, 2011 | 2006 Ford Five Hundred
The starter in my 95 Isuzu is going how do i replace it
I have pasted the procedure from autozone.com below, but I also recommend you read my starter post at http://www.fixya.com/cars/r5973094-starter_replace and let me know if you have questions.
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle on jackstands.
  3. Label and disconnect the battery and starter control wires from the starter.
  4. If equipped, remove the starter bracket and/or heat shield.
  5. Remove the starter-to-engine mounting bolts.
  6. Lower the starter from the engine. If any shims are present, keep them for reinstallation purposes.
To install:
  1. Install the starter and shims, if equipped, to the engine. Tighten the mounting bolts to 30-34 ft. lbs. (39-44 Nm).
  2. Install the starter bracket and/or heat shield, if equipped.
  3. Reconnect the electrical connectors to the starter.
  4. Lower the vehicle.
  5. Connect the negative battery cable.
  6. Start the vehicle to make sure the starter functions correctly.
SHIMMING
Starter noise during cranking and after the engine fires is often a result of too much or tool little distance between the starter pinion gear and the flywheel. A high pitched whine during cranking (before the engine fires) can be caused by the pinion and flywheel being too far apart. Likewise, a whine after the engine starts (as the key is released) is often a result of the pinion-flywheel relationship being too close. In both cases flywheel damage can occur. Shims are available in various sizes to properly adjust the starter on its mount. In order to check and adjust the shims, you will also need a flywheel turning tool, available at most auto parts stores.
If your vehicle's starter emits the type of noise previously described, follow the shimming procedure below:
  2. Raise and support the vehicle safely using jackstands.
  3. Remove the torque converter/flywheel cover from the bottom of the bell housing.
  4. Using the flywheel turning tool, turn the flywheel and examine the flywheel teeth. If damage is evident, the flywheel should be replaced.
Most starters are equipped with an access hole in which a small screwdriver or prybar may be inserted to push the starter pinion outward into contact with the flywheel.
  1. Move the starter pinion and clutch assembly so the pinion and flywheel teeth mesh. If necessary, rotate the flywheel so that a pinion tooth is directly in the center of the two flywheel teeth and on the centerline of the two gears, as shown in the accompanying illustration.
Normal pinion-to-flywheel clearance is about 0.01-0.06 in. (0.5-1.5mm).
  1. Check the pinion-to-flywheel clearance by using a 0.020 in. (0.5mm) wire gauge (a spark plug wire gauge may work here, or you can make your own). Make sure you center the pinion tooth between the flywheel teeth and the gauge-NOT in the corners, as you may get a false reading. If the clearance is under this minimum, shim the starter away from the flywheel by adding 0.04 in. (1mm) shims one at a time to the starter mount. Check clearance after adding each shim, but do not use more than 2 shims.
  2. If the clearance is over 0.060 in. (1.5mm), shim the starter towards the flywheel. Broken or severely mangled flywheel teeth are also a good indicator that the clearance here is too great. Shimming the starter towards the flywheel is done by adding shims to the outboard starter mounting pad only. Check the clearance after each shim is added. Add 0.013 in. (0.33mm) shims at this location, one at a time, but do NOT add a total of more than 4 shims.
Oct 28, 2010 | 1995 Isuzu Trooper
How to take a starter off of an 85 chevy caprice
Starter REMOVAL & INSTALLATION Fig. 1: If necessary disconnect the exhaust pipe(s) from the manifold(s) for access to the starter assembly 85313018.jpg Fig. 2: Once disconnected, the pipes should be suspended out of the way using wire or an old coat hanger 85313019.jpg Fig. 3: Although usually not necessary, the torque converter cover may be removed for additional access 85313020.jpg Fig. 4: Once the bolts are removed, the cover may be lowered from the transmission 85313021.jpg Fig. 5: The starter solenoid wiring should be tagged and disconnected 85313022.jpg Fig. 6: Various sized deep sockets will make disconnecting the wiring much easier 85313023.jpg Fig. 7: Loosen the start mounting bolts 85313024.jpg Fig. 8: Support the start and withdraw the bolts 85313025.jpg Fig. 9: Carefully tilt and lower the starter assembly from the vehicle 85313026.jpg Fig. 1: Check the gap between the starter pinion and flywheel 85313027.gif Fig. 2: Starter motor mounting — V6 (left) engine and diesel (right) engine 85313028.gif
Fig. 3: Starter motor mounting — inline six cylinder (top) and V8 engine with solenoid heat shield 85313029.gif
Starter noise during cranking and after the engine fires is often a result of too much or tool little distance between the starter pinion gear and the flywheel. A high pitched whine during cranking (before the engine fires) can be caused by the pinion and flywheel being too far apart. Likewise, a whine after the engine starts (as the key is released) is often a result of the pinion-flywheel relationship being too close. In both cases flywheel damage can occur. Shims are available in 0.015 in. sizes to properly adjust the starter on its mount. In order to check and adjust the shims, you will also need a flywheel turning tool, available at most auto parts stores or from any auto tool store or salesperson. If your car's starter emits the above noises, follow the shimming procedure below:
  3. Remove the torque converter cover on the bottom of the bell housing.
  5. Insert a screwdriver into the small hole in the bottom of the starter, then move the starter pinion and clutch assembly so the pinion and flywheel teeth mesh. If necessary, rotate the flywheel so that a pinion tooth is directly in the center of the two flywheel teeth and on the centerline of the two gears, as shown in the accompanying illustration.
  6. Check the pinion-to-flywheel clearance by using a 0.020 in. wire gauge (a spark plug wire gauge may work here, or you can make your own). Make sure you center the pinion tooth between the flywheel teeth and the gauge — NOT in the corners, as you may get a false reading. If the clearance is under this minimum, shim the starter away from the flywheel by adding shim(s) one at a time to the starter mount. Check clearance after adding each shim.
  7. If the clearance is a good deal over 0.020 in. (in the vicinity of a 0.050 in. plug), shim the starter towards the flywheel. Broken or severely mangled flywheel teeth are also a good indicator that the clearance here is too great. Shimming the starter towards the flywheel is done by adding shims to the outboard starter mounting pad only. Check the clearance after each shim is added. A shim of 0.015 in. at this location will decrease the clearance about 0.010 in. Battery and Starter Specifications Chart
    Battery and Starter Specifications Chart (Cont...)
Sep 01, 2010 | 1985 Chevrolet Caprice
Engine will not turn. When key is engage, the flywheel only take one tune then nothing.
Problem-
My Husky yth 150 has a fully charged battery, yet my headlights do not work adn it will not crank over. Could the starter switch be dead?
Jan 23, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
1989 Toyota Camry, the starter cranks, but with a
Check the backlash of the starter it may require a shimm if it has a high pitch wind when starting....make sure the flywheel isnt damnage or missing teeth...
May 19, 2009 | 1989 Toyota Camry
Garden Logo
269 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
