Question about Fisher and Paykel Washing Machines
Our smart drive C08 washing machine is really slow to fill on cold water. How do we fix this?
catriver
  • 878 Answers
SOURCE: Slow Filling only in rinse cycle
Tony, the fact that you are not receiving any error codes tends to leave me to believe that your cold fill hose filter may be restricted. Going by your model number you can enter this mode by having the power on at the source and off at the console. Press and hold the lifecyle button and then push power button. You should hear 2 beeps and then the display go blank. You can test the hot and cold valves by pressing how dirty up (hot) and how dirty down (cold). If you find the cold valve slow as in your rinse check for restrictions. If it were the thermistor, I would think you would receive an error code..Good luck.
Posted on Jun 06, 2006
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
SOURCE: Fisher&Paykel Smart Drive 601 Both Hot and Cold Water Fill very slowly
Hey there. I've had the same problem recently. It would fill slowly, and then after a while, it wouldn't fill at all. So I got some a new valve. it cost about $NZ30 delivered. You'll need one each for hot and cold. You can get parts from http://www.primedistributors.co.nz/. I think the part you need is 426142. you can check an image of it on the website. Good luck.
Posted on Aug 26, 2007
  • 209 Answers
SOURCE: kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Posted on Oct 14, 2007
SOURCE: Smart drive washing machine not filling properly?
There is a valve under the top of the cover were the bowl is This valve has a spring in it and this spring and valve can get stuck shut this stopping the speed of the water entering the machine it may stop it all together
Posted on Apr 03, 2009
Fisher & Paykel smartdrive 053 fills really slow
Your cold valve could be faulty & need replacing.
Try swapping hot & cold valves to see if it fills faster.
Jul 12, 2012 | Fisher and Paykel Washing Machines
Cold water filling is very slow despite good water pressure and taps fully turned on
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2011 | Hoover Washing Machines
No cold water coming into the washing machin
heatman101
Aug 10, 2011 | Kenmore Washing Machines
COLD WATER RUNS VERY VERY SLOW
heatman101
Aug 09, 2011 | Kenmore Washing Machines
Water when filling has slowed down cold water is very slow hot is ok
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Very slow filling of cold water. Hoover 5 Kg
heatman101
May 23, 2011 | Hoover Washing Machines
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Mar 30, 2011 | Washing Machines
Washing machine slow to fill
yes or a water pressure issue, mosty when using hot or warm
May 19, 2010 | Fisher and Paykel Active Smart E522B...
Fisher & paykel slow to fill?
if its the cold water (most common) replace the valve remove the two screws on the top of the control panel then you will see the valve i think its the right one looking from the front.its an easy job .hope this helps.
Mar 20, 2008 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
