Question about Logitech VX Revolution 931690-0403 Mouse
Mouse won't turn on
Hello, The problem that i'm having is that when I try to use the mouse it won't turn on most of the time. Before I when ejected the usb receiver the green light turns on but now it doesn't most of the time. what can I do? Thanks
  • Anonymous Mar 11, 2009
    i have the same problem, but thinking it was a simple problem I opened it up
    but doing this would have voided the warranty
    plz help me find a solution to fixing it due to no shop in Townsville have the same mouse
    New Friend:
My Mouse uses 5 volts I have used it before on windows 8 now it won't
turn on Help me
ps it is wired
Posted on Mar 08, 2013
    Problem Solver:
  • 10 Answers
The best thing to do , is if its under warranty take it back to the shop .
The product you have bought is faulty and will need to be looked at once taken back.
Even if your mouse is not under warranty/guarentee they should replace the item do to malfunction.
I hope this helps
By XBOX-SUPPORT .
Posted on Jul 31, 2008
My mouse pointer is frozen in the. Middle of the screen
Hello Anthony- do a cold boot on your computer; meaning turn off your computer through the normal shut down process. Wait a few minutes for RAM to clear completely. Start the computer..do you have the same problem? If so, you may have to update the mouse drivers. If you are using a wireless mouse, make sure you replaced the batteries in the mouse and that the mouse receiver is plugged in properly- maybe jostled loose somehow.
If you added new peripherals you may have an IRQ conflict.
Try booting up in safe mode, if the mouse works without freezing, try booting up - initializing one driver at a time to isolate the problem by process of illumination.
Feb 12, 2017 | The Computers & Internet
Tip
How to force an Apple computer to eject a stuck CD or DVD
Most of us have experienced it at least one, and if it hasn't happened to you yet, it's just a matter of time: a damaged CD, a failed DVD burn, or an unrecognized disc just won't eject from the Apple computer's disc drive. Here's a simple solution to force that stubborn CD out. Note: this tip requires a restart, so be sure to save any open files before proceeding.<br /><br />(1) Save any open files and documents and quit all open programs.<br />(2) Click on the Apple icon in the top-right corner of the screen and select "Restart." <br />(3) Click the "Restart" button on the message box that pops up.<br />(4) As soon as the screen turns black, before the computer begins rebooting, click and hold down the mouse button. See step 4(a) for more details about this step.<br /><span style="font-weight: bold;">(4a) If you have an older model trackpad, click and hold the trackpad button. If you have the new, button-less trackpad, click and hold down the trackpad itself. If you have a two-button mouse, click and hold down the left mouse button. If you have a wireless Bluetooth mouse, click and hold the left mouse button (though you may not have success with the MagicMouse; use a wired USB mouse if you have one available).</span><br />(5) Keep the mouse button held down until the CD/DVD media is auto-ejected from the drive.<br /><br />If the CD still remains stuck in the drive, there is a more serious problem at work, and the assistance of an authorized Apple technician will likely be required.
on Jun 21, 2011 | Computers & Internet
My Lenovo mouse won't work. It connects and registers but won't move? Is there any help?
Try booting to safe mode and check if your mouse works inside safe mode.
Restart the computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight either safe mode or safe mode with networking. Hit enter.
Once you are inside safe mode, check if your mouse works. If it works, then you just need to update the mouse driver. You can use RadarSync to search and install the update into your computer. You better use Safe Mode with Networking because RadarSync needs the internet or even the manual updating process needs an internet connection.
I hope this helps!
David
Apr 12, 2013 | Lenovo Computers & Internet
The mouse won't move
If it's the touchpad mouse - you may have disabled it by accident. For Acers, try hitting the Fn key and F7 at the same time.
If that doesn't work, you may need to connect a usb mouse and re-enable the touchpad. That should be in Control Panel -> Mouse -> Hardware.
Apr 11, 2013 | Acer Aspire One D260 Netbook
Hello..just moved my desk top to new desk..everything is fine..but mouse won t work..while it was unplugged i cleaned keyboard..monitor with soft cloth..can u tell me why my mouse won t work
IF it's a serial mouse (meaning green round connector) it's probably not plugged in correctly. Now these are not plug and play so you need to reboot your system in order for it to work. Try that.
Jul 10, 2011 | E-Machines eMachines Desktop PC
My hp wireless usb mouse won't connect. I have tried th connect button on bottom with no luck the keyboard works great but no mouse. please help
Make sure that the batteries are good and inserted correctly and that the LEDs (if any) light up.
HTH
Jun 18, 2011 | HP Wireless Optical Mouse
Won't start up....emergency eject????
As soon as you turn on your G5, hold down the mouse button. Keep holding it down until the disc ejects. Make sure you hold down the mouse button (right side or middle) as soon as you turn the computer on.
Verb
Apr 28, 2009 | Apple iMac G5 MA064LL/A Desktop
DVD reader
Hi I'm sorry you are having trouble,
OK, when was the last time your CD/DVD trey opened properly when instructed by pressing the eject button on your keyboard ?
This (and all other apple computers now) machine does not have a button other than the keyboard eject button to eject or open the trey. The eject button is usually the last key at the top right hand of the keyboard. If you are not using an Apple Keyboard, it does not always work. And, sometimes, that key no longer sends it's request to the Mac... SO,
Have you tried another keyboard ?
Is there a Disk in the reader? Sometimes the disk itself confuses the reader and paralyses it and restarting won't help it even freezes the system....
That is why there is another way to get the CD drive to open or eject a disk that won't come out:
Restart your mac or from an off position, turn on the Mac and VERY QUICKLY press the mouse button ( If you have a mighty mouse, be sure to click the left side of the mouse ) and hold that mouse button down until the disk ejects, depending on how much ram you have, it could take 10 seconds to 70 seconds, be patient...
If the Mac boots without ejecting the disk, then either your mouse or keyboard are not connected directly to the mac, this does not work well through a USB Hub, or the mouse or Keyboard are defective.
Keep trying it with other keyboards or mice until you get that drawer opened.
Mar 28, 2009 | Apple Power Mac G5 Desktop
Mouse doesn't turn on
This wireless mouse should have a transmitter that is plugged into the computer. Try replugging that in, and if there is a connect button on it, try pressing that as well.
Jan 29, 2008 | Logitech Inc MX610 Laser Cordless Mouse...
Logitech VX Revolution 931690-0403 Mouse Logo
563 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
