Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Just did a kitchen remodel and my Kenmore Elite fridge stood dormant for months. Just plugged it in and I get a sound of a working fridge and lights but no cooling in the fridge or freezer after many hours
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Sounds to listen for:
1. Compressor running
2. Evaporator fan inside the freezer compartment running
3. Condenser fan running in the back of the unit near the compressor.
All three of these must be functional to get cooling.
When units sit for a long time the 2 things that have a tendency to get stuck are the Condenser fan and the Evaporator fan. Should you discover that one of these fans is not running you can try to make it turn by pushing it through. Sometimes they will snap right out of being stuck. Other times you have to lubricate the fan with a paraffin based oil such as "Zoom Spout Oiler" or Union 76 Turbine Oil. The fix of last resort for a sticking fan is fan replacement.
Should all of the fans and the compressor be running the next thing of concern is a blockage in the coolant system from internal tubing corrosion. The blockage manifests at the Freon drier near the compressor. There is a tiny capillary tube on one end of the drier that the corrosion blocks the end of the tube. When this happens you can try resting the handle of hammer against one side of it and using the HANDLE of a 2nd hammer (i.e wood) to strike the drier on the side of the capillary end but DO NOT strike the capillary itself. This will sometimes briefly clear the debris and the cooling process works normally for a while. If there is loose debris in the cooling system it will more than likely repeat the blockage. The only fix for this if it keeps repeating is to have the coolant system serviced and the drier replaced.
If you need further assistance.. I will need a complete model number to better help you.
Thanks for choosing FixYa,
Kelly
Posted on Mar 11, 2011
    Guru:
  • 683 Answers
Have you cleaned the condensor coils? let me know. wally
Kenmore elite icemaker not filling with water - need help troubleshooting. Water has been disconnected for 2 weeks while remodeling the kitchen. Just reconnected. Water pressure is good Line is not...
The fill valve for the ice maker, where the house water line attaches has a screen to capture debris from the water line. Check that screen and clean it out.
Jan 17, 2015 | Kenmore Refrigerators
Kenmore range will not light, not getting gas flow.
Have you purged the gas line to get gas to the range? What is the model number?
Feb 10, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I recetly remodeled my kitchen. My fridge has not had the water conneted to it for a couple of months. i just connected it the other day and the ice maker does not appear to be working. What can i check?
make sure all ur wires are connected to the lil blue solenoid in the back where u hooked water up and make sure the plug on the ice maker is plugged up if it is try rotating the arms on the icemaker by hand and see if it may have just gotton stuck
Mar 01, 2010 | Refrigerators
Reversed a door
you should be able to reverse your doors just take bolts out on hinges pop out plugs on oppasite side
Aug 28, 2009 | Frigidaire FRT21H8 Top Freezer...
Kenmore Fridge Beeping
Try unplugging the power cord and then after 60 seconds plug it back in.
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
99 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
