Question about Honeywell Enviracaire Elite F300E-1019 Air Purifier
Honeywell Enviracaire Elite 300 problem. Light is not on. Seems like no power to system. No snapping or noises. No obvious bent fins or broken wires
    Guru:
  • 683 Answers
If it was wired to the return air it will have a flag switch to let it know the blower is on, sometimes the flag comes off and it wont operate, sometimes it is wired directly to the computer board on terminals EAC that stands for electronic air cleaner and the board turns the air cleaner on when the blower is running, if you have a meter you can check voltage in both places to see which one is the problem. let me know. thanks wally
Posted on Mar 11, 2011
Dear Expert, I do hear scary sound like a electric spark once in a while, and then stop. Should I turn off the switch? Thank you.
Arcing (snapping) seems too frequent
1. If the electronic cell(s) are wet from washing, turn the air cleaner off for two to
three hours.
2. Check the cell(s) for broken ionizer wires or bent plates. Repair if necessary.
3. Wash cell(s) and prefilter(s) if dirty.
Sep 28, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
F300e filter clicking
You may have a large particle of debris trapped or one of the cell plates is bent and too close to one another.
Jan 17, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
UV100E Ultraiolet system. Noticedbulb not coming
Honeywell has a great team of technical support personell, just call the number on your owners manual.
Jan 14, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have a HoneyWell F300E electronic air cleaner, installed on a furnace in a house I just bought. I have never owned one of these things before. The filter arcs and makes sparking noises constantly,...
Continuous snapping is not normal .Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can.
Jan 05, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have the enviracaire f300e 1001 in a house i just bought. i cleaned the filters. whenever the furnace turns on a buzzing comes from the unit. is this normal? the thermostat also flashes "filter".
Sounds like the filter is damaged or has bent fins.Make sure all the fins are not touching eachother, or they will arch and keep buzzing and flashing.Also there is a wire on the incoming air side of the filter(between each fin) to precharge the particales entering the filter .make sure the wires are not broken.good luck--Nate
Oct 29, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Power light not coming staying on...
pull the cells out and run the filter without them. If the light stays solid then you most likely have a simple short in one of the cells. Install one cell at a time, push it all the way back, close the door, turn on the fan. IF the light stays solid, that cell is fine. If the light flickers or goes out, the most common cause is a bent fin.
Look at the cells and see if any cells are touching or are too close, this will cause your problem.. Simply bend the cells to get even spacing and you should be ok.
Jul 15, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell F300E not cleaning air.
A newly installed system should still be under the contractor's labor warranty. Call them and ask them to come out to check on the unit and explain what you wrote above. This should cost you nothing and is the best way to get to the bottom of the problem.
Nov 09, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
F50E New Power Supply Arcing
check the fins on both cells for even spacing on the fins. If the fins are bent a little, this will cause your arcing.
Pull both cells out and reinsert them one at a time. Keep the cell all the way to the front or all the way to the back so it makes contact with the power supply.
The cell that has bent fins will continue arcing. Good luck.
Nov 13, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Clicking noise
I had the same problem.
We could put one cell in and it worked with out clicking. Putting the second one in solo however, it was clicking.
I looked closely at the second cell and discovered that two of the vanes on the side with the wires were bent at about 20 degrees off. Adjusting this and reinserting reduced the clicking but not completely. I pulled the cell and focused on the same two vanes and discover one was also bent in, gently pulled it back and no more clicking!
My wife had cleaned the filters and my 6 yr old and 4 year old had to help. I wonder how they got bent?!
We have had the cleaner for about 6 yrs and no problems until this last cleaning.
Be very careful in adjusting the cells. Aluminum does not like being bent and weakens each time it is moved, like pulling a tab off a beer can (of course the cells are made from much thicker and higher grade aluminum)!
Jan 23, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell Enviracaire Elite F300E-1019 Air Purifier Logo
383 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
