Question about Canon PIXMA MP830 All-In-One InkJet Printer
I have a CANON MP830 All-in-one printer and the problem I'm having is as follows: The paper I'm printing onto is in the lower feed tray. Since I installed fresh ink-jet cartridges, the paper is not printing out. The printing process begins, but the paper jams underneath the printer tray, -- and after it comes out approx. half the way, the Paper-Jam sign comes on, telling me to remove the paper and press OK. After rebooting a few times, this continues to happen and I'm not sure what is causing this, as I did not have the problem before I reinstalled fresh ink cartridges. Thank you for your assistance.
  • 22 Answers
Your Printer need a Complete Service. Please take this to any service center
Posted on Mar 11, 2011
I have a canon mp830 printer and the prompt says 'add paper'. there is plenty of paper. i have powered off several times and have changed and added paper, but it clicks and again says 'add paper' any...
hello, on the machines display/control panel there is a switch for paper feed, it might be set up for lower tray or back tray, depending on where you are feeding paper. also the computer usually overrides the printer, so might check to see if the paper setting on computer is set for the tray you are using.
Dec 27, 2010 | Office Equipment & Supplies
Fax output error
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes sucessfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Mar 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Paper is not loading
You possibly have an issue with your rollers. Remove the bottom tray to see if there is a paper jam or if the rollers are moving.
Spin the rollers to see if they are spinning as they should.
Remove some of the papers to see if the tray may be too full.
Make sure to log onto your computer and click the printer icon and remove any other pending jobs.
Restart the computer and the printer to ensure that both are starting correctly as they should.
Reload the paper in your printer, do a test page print job. Doesnt matter what you try to print, just print anything to give you an idea if the printer is working correctly.
Jan 29, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP830 fault code 6B10
Try to change paper size in the offending tray.
Jun 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error - Canon MP830
this Model has a paper tray on the bottom. Put some paper in the bottom tray and then voila..I had the same issue and i looked and the tray was empty..put some paper in..works just fine
Aug 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Pixma mp830
see if you can open a back door on the feed side. sounds like a paper is not feeding properly inside and must be removed.
Would be nice to know the model, make.
Jan 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 paper jam
Your "Best Solution" posted 10/01/07 needs just a little bit more. I followed the directions and saw the jammed paper but couldn't get hold of it. I then called Canon support and they told me that the green plastic can be pulled up and then the paper under it is accessible. I pulled up the green plastic and was able to grab the jammed paper and pull it out. He also told me that the solution could be found in the Canon knowledgebase with a color picture as well.
Sep 27, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma Paper feed not feeding!!
Either the pickup roller needs to be replaced,(a maintenance kit) or the tray isn't pushing the paper high enough to grab. Tyr loading a few more pages in the tray and making sure the tray is seated properly. Then try replacing the roller.
Sep 17, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
