Question about Home
When I flush my toilet the water goes down but then its as if big air bubble come up from where the water went down and splash some water out of the toilet. Everything was fine until recently. We've had a lot of rain lately, possibly high water table?
  • tony66451 Mar 11, 2011
    Thanks for the reply. I should have mentioned that I do have a septic system with a seepage pit.
    President:
  • 1,273 Answers
Two things jump out at me from your question.
For the water table to have any effect, you would have to have a septic tank with field lines.
Even so, air will not bubble back up into the toilet unless you have pluggage in the vent stack for the toilet.
I would suggest that a first move to correct the problem would be to locate the vent stack on the roof that is the vent line for the toilet and pass a plumber's snake down the line to clear it of debris and allow it to operate properly. It is possible that sewer gasses could infiltrate into the house if the vent line is plugged.
Best regards, --W/D--
Posted on Mar 11, 2011
  • woobie dog
    woobie dog Mar 11, 2011
    Please rate this solution so that we may continue to improve in helping others. Thanks.
Idman 605 serial number
Posted on Mar 20, 2011
We put in the toilet on sat. Since then every time you flush there is a big air bubble in the bowl, the other toilet we took out did not do this, poured a 5 lb bucket of water down it and that did
The new toilet has more flushing volume than the old one. The system should handle this. The problem could be the vents on the roof are plugged or something in the line is obstructing the flow. You will need to contact a plumber
Jun 08, 2015 | American Standard Home
How do I fix a toilet that bubbles (small air bubbles from below) and flushes slow, and not completely very often?
Remove the toilet & have a plumbing company power snake
as much of the entire homes waste drain as possible
Maybe clogged inside the home on most runs & also out to
the street,have them do as much as they can, out to the street
Remove all toilets, so they can do good job & you can check &
clean them from under it
Have them run a camera down ALL drains & to the street
Jul 19, 2014 | Briggs Abingdon Ada Toilet Express
Toilet not flushing completely
Prelude:
My toilet had the same problem a few times. I managed to clean it out because the pipe is somehow connected to the downstairs drainage pipe in my house. What fixed the toilet clog was going to the source of the problem and pouring extremely powerful hair clog remover chemicals in it (I did have to open all the windows and get the pets as far away as possible and wear a mask). After the specified amount of time waiting, I went to go flush and it worked.
**Answer**:
I would recommend doing the same thing but only if everyone in the house is gone for 1 hour. Also I would air it out by leaving windows open, not first floor doors or windows though. It can be deadly if inhaled for extended periods of time. The more powerful the cleaner, the better the results but the deadlier it can be if inhaled. Try this.
My second guess is that it may be the plug inside the toilet's tank. You should check to see if it is working properly. Try flushing with the lid off and watch the plug to see if it is working properly.
Mar 13, 2014 | Kohler Home
Bought a aqua option toilet dual flush from American Standard the tube that usually goes into the overflow tube now rides on a float which rises with the level of water as it gets closer to the overflow...
i have the same issue with my aqua option toilet. if you have a water shut off installed on the supply line to the toilet, just close it enough to reduce the supply pressure. no more splashing.
Nov 17, 2010 | American Standard Home
Cant find any thing in bowl ,replaced air tank drain is clear and still does not flush replaced bowl and flushes this is the 4th toilet with same problem cant find anything in any bowl we changed
Try turning off the water to the toilet, then old the handle down until you hear that all the
water has drained out of the tank. Then turn the water back on. Then take a cup of water
and put water on to the plunger on top of the tank. Check for air bubbles, if there are bubbles
then that is the problem. The tank MUST HAVE a certain amount of air in the top of the tank,
or it will not work at all. You might have to remove the plunger assembly and put some vaseline on the big O ring seals. To remove the plunger, take the screws off the stainless bent rod that goes
over the plunger, then remove the rod, or just move it out of the way. The plunger can be removed
by sticking the jaws of a pair of chanel lock "pump pliers", then grab the handles of the channel locks and turn the plunger assembly out.
Sometimes all you need to do is drain the tank down, and the toilet might work for a long time.
It's such an easy fix, a person really doesn't mind draining the tank.
Hope this helps
LeRoy Wolff , North Dakota master plumber # 8401
Nov 01, 2010 | Sloan M-101526-F Flushmate?® Complete...
Toilet when flushed makes a large bubble surface from the hole. Sometimes the toilet will not flush away a bit of tissue.... very frustrating..
Have you checked it out for any blockage in the toilet or drain line.
You could try a 6ft auger to try to remove blockage from toilet.
If it is a drain issue it is either blocked somewhere or the vent is not working correctly causing it to get air bubbles.
Check you tank for proper water fill level up to marked line. Also make sure fill line from fill valve is connected to overflow pipe to fill bowl up correctly.
Not enough water in tank will affect the flush.
Jun 11, 2010 | Home
I have a weak flushing toilet of this model. Water does not fill tank fast enough to create the weight of water needed to start a flush. I've looked in the tank while lifting the flap and see that as the...
From your description it sounds like the flushing orifices are plugged. The orifices are the little holes around the bowl or the big hole in the throat of some. A simple way to check if this is the problem is to get a bucket with aprox 2.5 gallons of water in it and pour it directly into the bowl and see if it goes right down. If it does, the orifices are plugged. Two of the most common causes of clogged orifices are hard water deposits and bowl cleaner cakes that drop in the tank. In the case of hard water deposits, we usualy acid clean the stool with muratic acid introduced through the flush valve. Be VERY careful when doing this, as the fumes are VERY dangerous and it can discolor colored porcilyn. May want to hire a plumber to do this. As for the cleaning cakes. You can pour some tap hot water through flush valve and dig into hole with wire hanger to remove as much as possible. I hope this helps.
May 19, 2010 | Pegasus Technologies Pegasus Elongated...
Fluids splash out when flushed
I went through this and called the help line. If the bowl is almost empty after flushing, it may be the water fill line in the fill tank (reservoir on the back of the toilet). There is a small tube that should go into the overflow tube and it adds water to the bowl after flushing. Mine was not attached to the overflow tube when I took it out of the box and the instructions did not mention to check it (or the troubleshooting guide). A picture is worth a thousand words so look for the small white hose going from the fill valve into the overflow tube:_1365.jpg
Nov 17, 2009 | American Standard Cadet 3 Right Height...
Pegasus HET toilet splashes water when it flushes
make sure the fill valve is not cracked,that's the long tower looking thing on the right side of the toilet when you stand in front of the unit. you can replace this part at homedepot. it is called a fluidmaster 400A.good luck.
Jul 16, 2009 | Home
New American Standard Flowise toilet won't flush
You have a sewer issue....it is entirely possible for other things to cause the toilet to loose water as they drain....but only if there is a sewer problem.....that is why there is an air gap between the toilet and the tank...(the trap) now I have been in this industry 35 years and the jet you speak of is in the bottom of the toilet that directs and forces flow down and out of the bowl as do the many small holes on the underside of the bowl lip ( I suspect ...as I have seen it MANY MANY time in the paste) that your old bowl may have had lots of calcium or lime build up (using lime a away occasionally helps) in the holes under the lip as well as other places...which reduces water flow and there by reduces pressure......but what you are describing is definitely sewer related....other water sources causing water to drain...bubbles...etc..I had a similar problem that occurred about once every 2 years in one of my homes...I had a tree root growing into my sewer line ...it would flush but on occasion...debris would get caught and a good plunging would help...but eventually...(twice) I had to rent a 3/4 inch snake from Time Rental...with a cutter head on it and remove the problem. Now your problem sounds exactly like an air gap problem...in that an overflow or something related is causing a vacuum assist when large amounts of water are drained...(ie...tub...washer...).as this happens the force the water carries and the lack of access to air in the flow causes vacuum "tugs" on other water sources attached to the sewer....take of your clean-out cover (usually in the back of the house and if you see water standing in it ....sewer problem....also you can have someone flush the toilet and eyeball the sewer/overflow...to see how it drains.
I hope this helps....good luck...thank you for rating my effort...the Fang.
Mar 27, 2009 | American Standard Colony 2388.012.222...
Home Logo
249 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
