Question about Ricoh Aficio 2018D All-In-One Laser Printer
Hi i just want to asked y my output xerox paper is getting dark? What is the problem on my unit?
  • 22 Answers
First of all do a service of your copier machine and clean all mirrors and lenses and the main glass.
then clean the chargers, transfer charger and primary charger. Primary charger is placed in Drum unit, clean the photo-conductive drum and its cleaning blade.
this may be useful for you
Posted on Mar 11, 2011
Xerox 4620 is printing smears all over the page. I replaced the drum but it is still happening. Not sure what could cause this prblem
ask yourself this . Is the paper warm or hot when it has been printed on ?
check fuser unit .
No heat equals unbonded toner on paper equals smearing of toner on paper.
Oct 20, 2015 | Xerox Laser Printers 4620/DN Phaser 4620DN...
How can I get the paper drawer for my Xerox Phaser 4600 to open? The paper tray is empty but won't open.
Hi Anonymous,
I suspect you must have solved this one by now.
I can only assume you have something jamed inside. (your thoughts too I expect)
I would have thought removing as many panels as you could to gain access to the drawer unit to add paper might reveal where the problem might be!
Good Luck.
Jul 02, 2014 | Xerox Phaser Office Equipment & Supplies
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
First print job, first page jams on output area
Please note that paper absorve humidity, try to keep you equipment in a dry place.
When the paper is that condition, and while passing thru the hot image drum, the sheet hedges sometimes curves and jams...
Sorry for my bad english !
Jun 23, 2009 | Xerox 4150V_P Printer
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Dark streaks
You need to remove the maintanence kit and clean the wiper blades there and where the paper comes out of the machine at the top. See below and check when your maintenance kit runs out and how to replace it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=389,E=0000000001343282793,K=7185,Sxi=9,Case=obj(947)
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=389,E=0000000001343282793,K=7185,Sxi=9,Case=obj(1031)
Nov 03, 2008 | Xerox Phaser 8500/DN Printer
Remove media from output tray
There is a small actuator on the exit sensor that has most likely fallen off. If you go onto Xerox.com and click on support, then in the search box enter phaser 780, then go to parts lists and diagrams. You want to look at Table 13 and Item 3 to locate where the problem most likely it.
If you need more help please ask.
Oct 08, 2008 | Xerox Phaser 780 Laser Printer
Xerox 416 Fuser
Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
Jan 25, 2008 | Office Equipment & Supplies
Ricoh Aficio 2018D All-In-One Laser Printer Logo
97 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
