Question about Hitachi 65SWX20B 65" Rear Projection Television
I have a hitachi 65SWX20B projection TV. When I power it on, I get no picture, no sound, and on one of the circuit boards, an LED (D967) blinks dimly (1/2 second on, 1/2 second off). A soft click is heard with each on/off transition.
  • Hitachi Master
  • 5,568 Answers
If the board with the blinking LED has larger than average parts on it, it is likely the main power supply and the clicking may be from a relay that is connecting and then, disconnecting the AC. With no video or audio, the main power supply has likely failed. Contact Hitachi service to ask how much the repair or replacement cost of the supply is. Make sure you have all involved model numbers handy; the one from your set with the mfr. date if present and if you can find an assembly number on the power supply itself. it may save you time and errors. These boards are often simply plugged into other assemblies with dissimilar plugs but if you decide to DIY, take some snapshots of the cabling to be on the safe side.
Posted on Mar 11, 2011
Hitachi 65SWX20B no picture/sound, 4 out of 5 green LEDs on, red LEDs on, green B+ LED is off. Pwr Relay clicks on, TV only turns on/off. IP02 location/How to check for 14-20V on terminal 4 of IP02?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 20, 2016 | Hitachi Televison & Video
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
I have a hitachi 60sbx72b tv doesn't display anything
Tries unplug for awhile replug see if it reset itself?Don't work or only for awhile happen again.The main video board must changed.
Jul 11, 2009 | Hitachi 65SWX20B 65" Rear Projection...
Hitachi 43UWX10B: Power light blinks continuously on and off, no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 08, 2017 | Hitachi 43UWX10B 43" Rear Projection...
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sound , no picture
i would check connections on your convergence ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 65SWX20B 65" Rear Projection Television Logo
192 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
