When I boot my computer, which runs Windows 7 64-bit, I get the RunDLL message, "LogiLDA.dll specified module could not be found."
I have the same problem logiLDA.dll not found. Look like this is a Logitech file that is for Logitech Download Assistant. You can go to start (type) msconfig and find it on the startup tab and disable it, I'm currently looking for a solution.
Posted on Mar 11, 2011
For some reason I encountered the same porblem: At startup I noticed that I was getting the error message "could not start C;/windowsSysten32\LogiLDA.ddl", which was interesting as my Window 8 was installed on H: drive. I went into the registry to HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run, found the entry calling for the this ddl to be called - changed H: for C: snf corrected the problem.
Posted on Feb 18, 2013
  • John Mulligan
    John Mulligan Feb 26, 2014
    Went to this registry entry and just deleted the Logitech Download Assistant entry from the RUN listing and rebooted. Install Logitech software if you need.
Regardless of this being over a year since the last post I feel the need to reply, for any who may happen upon it in the future, so that people aren't misinformed and think missing DLL's are a big enough problem to require a format and fresh OS installation, since that simply isn't the case.
Nobody ever had to format and install Win7 from scratch for a simple error caused by a missing DLL file. Especially if it's one that isn't even necessary or problematic. Unless the program that needs it is one you use even once a month, you won't have anything to bother worrying about. Missing DLL's are easy to fix. Google search the full file-name (????.dll) + the word download, which will usually point you to what you want quickly. If you really can't find it (sometimes it's from an old or obscure program) you have 2 options. First is to uninstall the program in question entirely (via Programs & Features in the Control Panel), and if that isn't possible for some reason (such as the program not being listed) or you just don't want to remove it for nothing then you can disable it.
Press the windows key and in the start search type msconfig and press enter. The window that comes up can seriously impact your pc in a bad way if you do something you shouldn't, so be careful and don't rush. In the tabs you click on Startup, and it shows a list of all programs that loads when the OS is booting up. Startup Item (Program name), Manufacturer (Which company produces the software), Command (The .exe command line that launches the program), Location (obvious), and Date Disabled (If you disable something it keeps track of when)
Generally disabling something here can't hurt anything even if you disable the wrong thing. Just click the check-box to de-select the program, and click apply. Whenever you next restart (it prompts you to right away) the program simply won't load, and so the DLL error message won't come up. You can also do the reverse, and set a program to load that you previously disabled, in case you disable the wrong thing or found the DLL and want to use the program again.
Posted on Aug 02, 2012
  • phat_71
    phat_71 Aug 02, 2012
  • 94 Answers
You must reinstall your pc with win 7
How to fix a rundll error on windows xp
You hope you were smart enough to run backups and do a system restore from one of them.
Feb 04, 2014 | HP Computers & Internet
It gives messsage for dll missing.
From what i have read, this is malware, a trojan.
You need to get rid of it.
Run a program like Malwarebytes in safe mode (F8 on boot, choose safe mode with networking) also run with system restore OFF, lots of malware and viruses hide there.
Follow this guide....
http://www.fixya.com/support/r5272277-secure_clean_computers
Jul 27, 2010 | Microsoft Windows Vista Ultimate with SP1...
Everytime I start up Windows I an error message.
Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
Run DLL, VTURQjKC.dll problem
smash with hammer and try again
Apr 21, 2010 | Computers & Internet
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
In windows vista ultimate 64 bit. most of the items in my control panel will not open up. I get this message. c:\windowssystem32 undll32.exe file name or extension is to long. can you please help me. jim
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } hi
The rundll32.exe process is responsible for running DLLs and placing its libraries in the memory. The rundll32.exe process is known as a command line utility program, and it performs its embedded functions along with the rundll.exe file. Rundll32.exe works by invoking a function that is exported from a specific 16-bit or 32-bit DLL module. However the only DLLs that you can call with the rundll.exe and rundll32.exe files are the ones that are only specified to be accessed by these processes.
The rundll32.exe file operates by parsing the command line. The specified DLL is then loaded through the function LoadLibrary(). Afterwards, from the function , it gets the addresses through GetProcAddress(). The command line tail is passed when the is called. Next, the DLL is unloaded upon the return of . Finally, the rundll32.exe file exits.We strongly recommend that you run a FREE registry scan to identify rundll32.exe related errors.
if you have any question or any futher assistance you can get back to me on fixya for same
thanks
techbuddies
Oct 25, 2009 | Microsoft Windows Vista Ultimate Edition
Deleted by mistake 3 rundll modules
You needs to restore Your OS or format entire Disk Partition and install fresh OS.But be carefully fresh OS will deleted entire data of UR partition.
May 18, 2009 | Microsoft Windows XP Home Edition
RUN DLL ERROR
IF YOU HAVE ANOTHER COMPUTER IT WOULD BE EASIER, IF NOT YOU WILL HAVE TO PRINT OUT THE INSTALLMENT DIRECTIONS FOR ELIMINATION OF THE ERROR PROMPT. IT'S TIME CONSUMING SO IF YOU ARE IN A RUSH, FORGET IT.(UNLESS YOU ARE A COMPUTER GEEK) :) YOU WON'T BE ABLE TO ACCESS WINDOWS FROM THE COMPUTER WITH THE ERROR, GO TO ANOTHER COMPUTER, PULL UP WINDOWS SUPPORT, THERE'S A SECTION THERE FOR ERRORS, IF YOU DON'T SEE IT RIGHT OFF, JUST DO SEARCH ON THE LEFT HAND SIDE BAR, "DLL" OR "ERRORS" ANY OF THESE WILL PULL UP YOUR FIX. PRINT 'EM, APPLY, AND YOU'RE UP N RUNNING!!!
Oct 24, 2008 | Microsoft Windows XP Professional
M3plugin.dll
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.  Solve my this problem as soon as possible.
Aug 26, 2008 | Computers & Internet
Computers & Internet Logo
3,899 people viewed this question
David Payne
David Payne
