Question about Kirby Ultimate G Bagged Upright Vacuum
My G6 Vacuum won't start, and I was wondering ifd it had a restart button? It does, I can not find it.
  • 240 Answers
The Kirby does not have a restart button. There are a number of reasons why it may not start. First be sure the bag assembly and rug head or hose are properly in place. The motor will not run without them firmly in place. If this is not the problem, the next thing to check is the cord. Remove the plastic cord cover on the base of the unit, pull the cord straight out to unplug it, and check the cord for continuity with a voltmeter. Wiggle the cord around a bit to be sure it is conducting current continuously. If the cord is good, either the switch has failed, or the carbon brushes in the motor have worn to the point where they are not making good contact with the motor armature. This will usually require professional repair.
Posted on Mar 12, 2011
My G6 after turning on does not run untill you rotate the beater brush
sounds like the drive belt has been overstretched. replace with a new one and see if that helps.
Jan 08, 2014 | Kirby G6 Bagged Upright Vacuum
Roomba 4210 won't start
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle
    Dec 22, 2012 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Is there a reset button for Kirby G6?
    One set button on your Kirby. Remove the head to check for blockage in the fan.
    Aug 14, 2012 | Kirby G6 Bagged Upright Vacuum
    Kirby g6 will not pic up dirt. Belt is on and bag
    check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
    Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
    Light doesn't work
    go to a vacuum repair shop and take the old bulb with you along with the model number and make of your vacuum cleaner
    Apr 23, 2009 | Kirby G6 Bagged Upright Vacuum
    Vacuum g6 won't turn on
    Hi
    Either the bag or the main head is not locked on correctly
    Feb 22, 2009 | Kirby Ultimate G Bagged Upright Vacuum
    Kirby G6 Power Switch Test ?
    You can look at the wiring diagram and try to figure out how to use a circuit tester to test the switch but I would just suggest just swapping it for a good one (always good to have one good switch for testing) and see if it solves the problem.
    Good Luck
    Rocky
    Oct 27, 2008 | Kirby G6 Bagged Upright Vacuum
    Owners manual for kirby g6
    The Kirby G6 Vacuum Manual is available for free on this site: http://ubermanuals.com/product/kirby-g6-8499 .
    May 13, 2008 | Kirby G6 Bagged Upright Vacuum
    Kirby Ultimate G Bagged Upright Vacuum Logo
    571 people viewed this question
    Top Kirby Vacuums Experts
    JoeVacs
    Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
