Question about Epson PRINTER, 4800 PORTRAIT EDITION :unitsize C593001EXP
I dont have any coloured ink cartidges left and need to immediately print some forms in full black will be okay but i cannot change my colours to black as the ink holder stays on the far right of my epson and wont come across for me to change ink what can i do to bring it into middle to change ink
    Problem Solver:
  • 8 Answers
To print in all black, you can change a setting through the computer to tell the printer to only use the black ink. This is better than putting black ink where the color ink normally would go as that would cause the shading to be wrong and potentially ruin the documents.
If you have enough black ink in the printer, before you finalize the printing process make sure you have black and white only selected.
This will allow you to print without getting access to the ink cartridge holders.
Good luck hope this helps.
Posted on Mar 11, 2011
  • eugeniemm May 04, 2011
    How to tell to the computer to use the black ink only? You documents are out of date and there is not an option in the latest printer preferences.
Epson l200 is not able to print black colour. It can print colour picture without black colour. Ink is sufficient.
It's probably that the spray nozzles which are very very small .. have become blocked.
You can try removing the cartridge and wiping it with a tissue with a drop of vinegar on. If that doesn't work, you need to replace the cartidge
Feb 24, 2016 | Epson Office Equipment & Supplies
Cannon S330 Printer was operating correctly, print cartridges required new. cartridges changed, will not print, after a time then would print black only, after more time colour began to print for several...
Sounds like your print head may be faulty. If you can, get it replaced. This is caused by using recycled cartidges or faulty ink cartridge.
Thanks,
Lolita
Jun 12, 2008 | Office Equipment & Supplies
I was low on black ink and needed to print flyers , the Epson 630 asked me if i would like to continue printing and use other colors , i pushed yes, and have changed out ink and its still prints in r
Is it possible that you accidentally put the wrong colour cartidges in the wrong spots? Otherwise, it should work fine. Also, the printer's default is usually to print in colour, therefore even pages in black and white will usr colour, which uses up coloured ink. Always check the prooerties when printing to switch to b&w:)
Jan 20, 2014 | Epson WorkForce 630 Wireless All-in-One...
Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
Apr 27, 2010 | HP Color LaserJet 2600n Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
I have a hp psc 2410 .the black is printing beautifully but the colour it printing doubled or blurry. changed colour cartridge and still the same. help please
Your inkjet nozzles may be clogged with old dried ink. Try removing your color cartridge and looking at the area on your print carraige where the inkjet cartridge mates up with the carriage. Use a Q-tip and warm distilled water to gently swab this area until all the old ink is dissolved and it wipes clean. You may need several Q-tips for this. Allow to air dry and reintall your print cartidge. Your printer should go into an automatic cleaning cycle. You may also need to gently clean the area on the cartidge itself using the Q-tip method. Good luck.
Feb 20, 2009 | HP PSC 2410 All-In-One InkJet Printer
Possible to print only black when colour cartridges are empty?
This printer does not let you print if even one of the cartidges is out of ink. I suggest you replace them and then in the printer properties change your settings to the way you want color to be spent.
Aug 04, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Why does it keep running out of color ink, while printing only Black and White?
Whilst you rarely print in colour, its important to know that you should try to print in colour at least once a week. This will reduce the risk of your colour nozzles blocking up.
Many people have gone out to replace their 'hardly used' colour cartridges when they dont work, thinking that they have dried up, when infact its simply blocked nozzles.
If you want to keep your colour nozzles and ink ready to run, just do a full colour alignment every 1-2 weeks. Minimal ink usage there and you keep your Canon MP780 running well!
Jan 12, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Epson PRINTER, 4800 PORTRAIT EDITION :unitsize C593001EXP Logo
146 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
