Question about Craftsman 10" Table Saw
Motor makes horrible noise - Craftsman 10" Table Saw
    Sergeant:
  • 259 Answers
It could be the bearings in the motor are bad. When you turn the saw on does the motor pulley turn. If not the motor shaft could be turning inside the pulley. Make sure the pulley is not loose on the motor shaft. If the motor just hums without spinning it has an internal within the motor itself
Posted on Mar 11, 2011
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Why is my ID Armor ID-XC200D making a horrible noise when I shred?
kkrenn641:
That "horrible noise" is probably caused by the shredder gears meshing improperly. If you disassemble it again and look carefully at the gears, you will most likely see that some are not mating properly... Usually the motor gear and the first idler gear that meshes with the motor gear. If those two gears seem to be separated a bit, or slightly mis-aligned look carefully at where the motor mounts, and you may see that the plastic "bed" where the motor is mounted has melted from heat from the motor. This is caused by using the shredder too long without letting the motor cool down. You may be able to shim the motor housing to realign the gears, if you have the patience!
Sep 13, 2012 | Staples ID Armor SH2836ID2836 Shredder
My volty is making a large sound when I hit the start switch I just changed the starter motor , but still making a horrible sound when trying to start it.?
U forgot to CHECK the BENDiX gear!
Thats the thing that makes that horrible sound!
It might STOCK or needs a lubricant!
Check that and i assure u thats the fault of that noise!
Nov 23, 2010 | 2000 Suzuki Volty
I have a Gelatao Magnum Plus that makes a horrible sqeaking noise
Maybe blade assembly it's loose, or bearing are dry, if you can take apart, use grease on the shaft and bearings. or replace motor.
Dec 23, 2009 | Kitchen Appliances - Others
Motor or beater bar making horrible noise
The belt could be damaged. Call the Dyson helpline. They will listen to the noise and troubleshoot it for you. If it is the brushbar motor they will have a repair dealer look at it. If it is the belt that is damaged, their solution will depend on whether your machine is still under warranty or not.
Jul 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
MAKES HORRIBLE NOISE AT THE START, SEEMS TO WORK OK OTHERWISE
The first step in a dishwasher's program cycle is activating the drain pump. If there are obstructing objects in the impeller it could make noise, also if the drain pump's bearings/motor is damaged. I don't know what you meant by taking out bottom part, maybe it was the drain pump you checked?
If you didn't this is normally an easily accessible component, when you have it out you can also check that the impeller rotates freely and that it feels and sounds ok in the bearings.
Maybe there is a possibility to attach a sound file here, it would help to diagnose the problem.
May 22, 2009 | Maytag MDB7100AWB Dishwasher
Machine does not spin, it only makes a horrible racketing noise
Sound like you have a busted coupler .It is located between the motor and trany.Cheak inbetween .hope i helped.:)
May 18, 2009 | Kenmore 22422 Top Load Washer
Turntables doesn't work and makes horrible noise
Replace turntable motor. Not really that hard to replace or expensive. Remove all screws holding bottom panel (usually three across each side and one to three in front) to gain access to the turntable motor. The panel will hinge in the back.
Jun 01, 2008 | Frigidaire PLMV168 Microwave Oven
Horrible noise
it is the color wheel i have a similar problem and am looking for the part, the color wheel is a small electric motor that spins at a high speed and it can go bad. which will lead to the horrible squeel/hum/buzz.
Apr 24, 2007 | InFocus ScreenPlay 4805 Multimedia...
Craftsman 10" Table Saw Logo
241 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
