Question about Frigidaire Dishwashers
My dishwasher model:FDB710LCS0 won't drain. I tried to take out the parts, it still won't drain. the spinner also would not spin, but water would still come out of it.
4 Suggested Answers
  • 1462 Answers
SOURCE: Bosch Dishwasher
the spray arms are rotated by water coming out of angled jets, this water being forced round by the main circulating pump. suspect it may a fault with this pump
Posted on Mar 24, 2007
  • 423 Answers
SOURCE: whirlpool dishwasher top Spinner and top rack
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Posted on Sep 12, 2009
oldTech2332
  • 2341 Answers
SOURCE: I HAVE A MAYTAG DISHWASHER MODEL- MDB5000AWA. IT
Their is a couple possibilities
1) the water level in the tub is insufficent. It should be level or just above the heat element. If not at that the level as long as water pressure to the dishwasher is good the water inlet valve that the water supply connects to is bad
2) the filter inside of the pump is clogged and water is having a hard time getting into the pump to circulate. This link http://c.searspartsdirect.com/lis_png/PLDM/M0203021-00006.png shows where the filter is (item#6) to get to it unscrew the tube on the top of lower wash arm(not shown is the drawing) remove item#2&36 then item #4 to get to the filter
if water valve needs replacing its part#99001359 it could be purchased at your local appliance parts store or online at;
repairclinic.com
appliancepartspros.com
apdepot.com
assuredparts.com
Good luck,i hope this helps,
Gene
Posted on Aug 04, 2011
Spinners don't appear to spin
the elements should not be red as this indicates a lack of water to cover the elements
that would account for the spinners not working as the pump will not be pumping water to make them spin
check the water level or call a technician to diagnose the problem properly and quote
Sep 26, 2016 | Dishwashers
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
Dishwasher will fill and empty but no water coming through the spinners
It would help if you provide the model number.
Usually the problem is with the wash distributor circuit. The water alternates between bottom and top spinners (wash arms). The distributor may be faulty assuming the arms are clean and you have checked this. Some models use the same pump for wash and drain using impeller. In that case the problem could be the impeller is clogged and not allowing water to get in the arms. See this diagram.
Model number will help identify the part.
Dec 29, 2012 | Hotpoint Dishwashers
I have a frigidaire 9 cylce-heavy duty-2speed ,model fws445rfs0. It fills with water, drains water but won't spin on the spin cycles. I was trying to remove the middle spinner piece inside to see if...
for schematic try:http://www.partselect.com/ModelFrames.aspx?ModelID=1004870&ModelNum=FWS445RFS0&mfgModelNum=&ManufactureID=4&Selected=ZH8J52ZV&Position=4&mfg=Frigidaire&Type=&Mark=4
Feb 02, 2012 | Frigidaire Washing Machines
My kenmore m # 66515829 the water jet spinner under the top basket is not spinning to clean the dishes, I have set it in a postion closed the door let it run then open and it is in the same spot. I have...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 17, 2011 | Kenmore Dishwashers
DISHES ON TOP RACK ARE NOT GETTING CLEAN TOP SPINNER NOT SPINNING POSSIBLY NOT ENOUGH WATER PRESSURE?
It would help if you provided the make and model of the dishwasher.
Most likely cause of not getting enough water pressure to top rack is the water diverter may be faulty.
Depending on the model - it is a small ball floating in a vertical channel which alternately opens and closes the bottom and top water inlets to the spray arms. Check part at Repair Clinic after selecting make & model of your dishwasher.
Jun 17, 2010 | Kenmore Dishwashers
Top Wash Arm not Spinning
water is not circlating, you need a circulation pump
Feb 24, 2010 | Bosch 24 in. SHV55M03GB Built-In...
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
May 13, 2009 | GE GSS1800H Built-in Dishwasher
Bosch Dishwasher
Mar 23, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
96 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
