Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
The brush stopped revolving. I don't see anything blocking. It sucked up a corner of a rug for a split second but didn't pull anything off of the rug, ie, nothing from the rug is in there. Do these have belts? I don't see that. vicki
    Problem Solver:
  • 8 Answers
Although I do not share the exact same model that you have, there is a belt in the one I own.
Checking it was pretty easy as the unit comes apart in a simple manner.
I do not know how your unit comes apart but look for screws or screw holes that hold the area in question together and remove.
The belt for my unit is tiny and somewhat hidden near the edge of the unit. The brush was powered by the suction of the vacuum using small paddles that caught the wind. If your unit has this then make sure the belt is still attached and whatever is powering the belt is operating properly.
Good Luck hope this helps.
Posted on Mar 11, 2011
Why won't my shark navigator cordless vacuum pick anything up?
Sometimes everything seems to be fine. The brushes turn, but if the brushes aren't cleaned of hair, rug tangles and so on, the brushes on the vaccum get filled and it won't puck up anything. ON THE OTHER HAND if the brushes are clean, did you check all your hoses from thr base of of vaccum where things get sucked up to the bin?
Jan 27, 2016 | Shark Vacuums
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My husband sucked up part of a rug. The belt didn't shut off like I thought it was supposed to. Now there is a funny loud hum when the brush is running. There are also some fuzzy disc-like things around...
See if you can take the brush assembly off. There should be a plate and 2 screws. One on each side. You can lift out the brush and get all of the strings and such off of the roller brush. You might have to go a little deeper with it open and see if anything got sucked up the vent way.
Jan 06, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
Floor level brush stopped rotating after it caught
Look at the bottom and check a thread of carpet isn't wrapped around the brush, if so try pulling it off or carefully cutting it off. You'll probably see a collection of fluff etc above the brush that's stopping it from sucking up, pull this out, or it just may be that cause the brush isn't working its not picking up.
If this helps please rate me
Jun 20, 2010 | Bissell 6594 PowerForce Bagless Upright...
My brusg stopped turning after sucking up a shoe
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first. Did this fix your problem? If no, please let me know and I'll be more then happy to do some more advanced diagnosing with you.
May 02, 2010 | Dyson DC25 All Floors Bagless Upright...
Is the Dyson pulling carpet fibers, not dirt ?
You need to shut the brush roll off. It is ruining your rugs, the dyson has a very aggressive roller and can hurt some types of rugs and carpets.
Aug 17, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar sucked up corner of throw rug and now it doesn't turn.
Take the head down and clean the brush and when you put it back together it should be back in sync.
Jul 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My shark v1917 jammed on a throw rug, won't start.
These machines do break VERY easy, however i would wait a couple of hours and try restarting it. If this does not work then i am sorry to say yes it is scrap.
Apr 15, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
409 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
