Question about Cleveland Electric Powered Convection Steamer
I have a tabletop cleveland steamer. When the water fills in the tank it starts coming out inside the steamer where the steam should come out. I delimed it as the delimer light was on, this corrected the problem for about a day but now having the same problem. could this be the pressure valve and how difficult is it to replace? Thanks for your help
  • 37 Answers
The problem is it is over fillin.It could be dirty probes for the water level or the water fill valve could be stickin.
Posted on Apr 24, 2011
When you push the start button the oven shots off
PDF]Convotherm by Cleveland Service Manual.pdf
manuals.therrconline.com/.../Cleveland/convotherm%20by%20cleveland...
Cleveland Range, LLC ... After the first signal (do not press Start/Stop) open door and spray the oven ... After the next signal, switch the combi steamer off and thoroughly wash out the oven ... Service Handbook OEB/OES/OGB/OGS ..... steam injection (controlled via the bypass probe) is depressed until the Crisp & Tasty.
Sep 08, 2015 | Cleveland Range Cleveland OGS-10.20...
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
I have an Ariete coffee machine the steamer takes along time to heat up not much steam coming out
if the steamer is not been in use for a ling time is possible tha the valve got stuck. You can try to open and close the steam handle repeating that very often while steam get out. if it does not work try to make a cicle of water mixed with salt, just start the coffe maker, warm up and start WITHOUT COFFEE, you repeat that several time to obtain clean water from the fiter, warm up for steam function and start to open-close the steam handle on the right of the coffee maker body. If that doese not helps you must change or repair the rubinet-valve of steamer, apply to assistence.
Sep 08, 2013 | Ariete Cafe Retro Espresso Machine
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Conair Lysol hand held steamer
Does it tell you to add salt to the water?(I have a cheapo little steamer that requires salt to increase the conductivity of the water-it just creates steam by running AC voltage through the water in the tank)
May 25, 2013 | Heating & Cooling
My steamer spits out water but not steam
It sounds like you may have mineral buildup in the system. You can try filling the water tank 2/3 with water and then filling it with white vinegar. Steam until the tank is empty. This should clean the buildup out of the machine.
By the way, Rather than just running the vinegar/water out, this solution is good for bathrooms, kitchens, sinks, showers, and windows.
Feb 26, 2011 | Scunci 900 Handheld Steam Vacuum
While in operation the steamer makes a banging noise sounds like it is coming from the drain line and inside the steamer
You did not post the info on the item. Many things that heat water to a boiling point have this problem as they age. The reason is due to pitting of the heater unit or accumulation of scale and mineral deposits. This causes hot spots in the boiler and you hear the steam pockets expanding
Jan 27, 2011 | Cleveland 208/3 21CET16 SteamCraft Ultra...
Shark Steam Mop - Gray/ Purple Vacuum: My shark steamer is heating up but not steaming. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
New solenoid drain valve for cleveland steamer
The correct cleveland part # for your valve is 22221. If you have the correct valve there should be no extra ports. The steamer will flush itself when you turn it on, and periodically if there is the optional blow down timer installed. Hope this helps
Apr 02, 2009 | Cleveland Electric Powered Convection...
Steamer
Both tubes must be in the water. If you haven't used the machine for awhile, fill the water canister, turn the espresso maker on and also turn on the delivery switch (the top switch on the EC140). You'll hear the pump and in a second or two water will begin to exit the boiler nozzle. Immediately turn the delivery switch off. Wait for the "OK" light to come on. Press the "Steam" switch (the middle switch on the EC140, place an empty cup under the frother and turn the steam control knob on top in the counterclockwise direction. Steam will come from the frother. Be very careful to avoid contact with this steam.
Apr 23, 2008 | DeLonghi EC140 Espresso Machine
Cleveland Electric Powered Convection Steamer Logo
207 people viewed this question
Top Cleveland Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Cleveland Electrical Supply Expert? Answer questions, earn points and help others
