Question about Kitchen Ranges
Kenmore infinite switch will not stop clicking after lighting
  • 93 Answers
A little school lesson. Infinite switches on on electric ranges and cooktops. If you have clicking is it a gas range or cooktop? I have never heard of an infinite switch clicking. If it is gas, have you recently cleaned around the knobs? If not, that paticular spark switch will need to be changed. And if they are not wired individualy, the whole harness will need to be replaced.
Posted on Jul 31, 2008
How do I access infinite switch on kenmore stove? see picture
Kenmore not much different than Whirlpool pull oven out remove back panel remove knob from switch pulls off either 2 screws or a nut holding switch
Feb 10, 2015 | Stoves Kitchen Ranges
Kenmore 790 range infinite switch
what is a infinite switch and where is it?
Feb 08, 2014 | Kenmore 95002 / 95004 Electric Kitchen...
The "element on' light on my Kenmore Electric Range wont turn off.
The element on indicator is typically controlled by the infinite switch (the temperature control) for the element.
Jan 01, 2014 | Kenmore 96412 / 96414 / 96419 Electric...
I have an Kenmore stove oven. It is a glass top stove that I bought in 2002. The front right element won't shut off.
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Feb 05, 2011 | Kenmore Ovens
I have a Kenmore Electric Range (Model C970-629934) and one of the large burners only works as high heat - doesn't matter if I set at low the burner gets blazing hot??
Nov 18, 2010 | Kenmore Kitchen Ranges
Have a Kenmore electric range. A model C880 sold by Sears Canada. One of the "element on" indicator lights stay on even though the elements are not switched on.
Oct 23, 2010 | Kenmore Kitchen Ranges
At first I thought I only had a burned out drivers' side headlight. I replaced it and it worked. But neither of the two high beam lights work. In fact, when I turn on the high beams, all the headlights...
You have a rusted out ground leads to both front lamps. It may be bad enough rusting up front that effects both fenders. Run some heavy ground wires from negative of battery to both fenders, then tie in the negative lamp leads to the fenders. Might as well make sure the ground connections to everything else are holding up as well. I've added grounds to windshield wiper motors and blower fans that quit working as well.
Aug 09, 2010 | 1987 Chevrolet Nova
Kenmore electric stove with glass/cermanic top. Element on light indictor light stays on all the time even though no burners have been turned on for 5 hours. None of the burners are hot when you run your...
Tony, this sounds like you may need to have a new burner switch installed, it is called an infinite switch. If it is for the dual burner, make sure you tell the appliance parts store this so they can order you a dual infinite switch.
Nov 08, 2009 | Kenmore Ovens
Kenmore stove surface unit light stays on
When the indicator light does not shut off when the burners are turned to the off position, this indicates one of the infinites switches are shorted. If comfortable with electricity, unplug the unit and remove the rear cover exposing the infinite (burner) switches. Using a bright flashlight, shine directly on one of the switches and you will see the following markings. L1 - L2 - H1 - H2, and then the Letter P. This letter P is for the pilot light. Since there is no way of determining which switch is shorted, remove the wire from the letter P on one switch. Isolate the wire removed so it is not touching anything. Place a piece of black electrical tape around the end to be safe. Next, plug it back in. If the light is still lit, move on to the next one until you have found the switch that once the wire is removed, the light does not light anymore. Replace that infinite/burner switcha nd all is well. If I can help further, I am here.
Waiting to hear from you,
Eric Campion
Feb 13, 2009 | Kitchen Ranges
Kitchen Ranges Logo
471 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
