Problem is: i have an older rca scenium 52" and my newer HD cable wont plug into the older plug in the tv. can i purchase a cable that will take cae of this problem?
  • 25 Answers
By "newer HD cable" do you mean HD cable box? Most cable boxes have a variety of ways you can connect them to the TV. The latest and greatest for newer TVs is over a connection called HDMI. Your TV probably doesn't have that and that could be what you are referring to. The other connections are called component and composite and consist of a number of colored plugs that you just match up. This could be the case but it is possible the cable company didn't provide you with the cables you need. Lastly, you should be able to connect the TV using a coax cable (the kind that usually has a nut at the end).
Posted on Mar 11, 2011
There's a buzzing sound coming from our RCA Scenium tv, how do we fix it?
Are you using RCA type audio cables?, if so, make sure the connectors are tight and the cables are not frayed, it also helps routing those analog cables at least 8 inches away from any power cords or transformers. Buzzing usually is caused by loose ground connections or RF interference.
HDalacarte.com guy, audio/video/computer technician for over 30 years
May 26, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I won a rca scenium 52 inch hd tv.. i hit somthing on my remote and now i have a fuzzy scree. and dont know how to fix it.. i trouble shooted with dish network. they say it is my tv. but the dvd player is...
Hello. I do hope that you have gotten this resolved. But if not, here are some simple steps.
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable- the TV needs to be on an HDMI input
If you are using component cables-the TV needs to be on a component input usually
If you are using RCA cables-the TV usually needs to be on a VIDEO like Video 1 or2
If you are using coax cable-the TV needs to be just on channel 3 or 4.
Becki Barned
DISH Network Customer Service
Feb 12, 2011 | RCA Scenium M50WH187 50" HDTV
It seems has if the HDMI port on my Scenium is going bad. For quite a while, it would occasionally turn people's skin blue. Pulling out the HDMI cable and reinserting it would usually correct the...
hi,
Your TV didn't have any HDMI port. Do you mean the DVI port. do you use DVI cable or DVI to HDMI cable.
The only way to check whether the DVI port is working or not is by replacing the cable. purchase a new cable and try again.
ok
Jan 31, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a 52 in rca hd. the cable man came the other day and brought me a HD box for my tv. I cant find where to connect the HD in the back of the tv. the cord fits the box but I have ideal where to plug...
There should be an HDMI plug in the back of the TV.That is where to plug it .If you don't have that cable then you could use the red green and blue component plugs instead
Feb 14, 2010 | RCA R52WH73 Projection Television
I have a RCA Scenium D52W135D, that wont come on. every great once in a while it will. When you plug it in it starts to warm up then shuts back down. Keeps repeating. It flashes a code at you through the...
have scenium d52w135d combo burnt power resistor in deflection board,do i need to replace the the whole board? or just the resistor,and where can i find this resistor?
Nov 03, 2009 | RCA D52W135D 52 in. TV/DVD Combo
52 inch rca scenium wont turn on
this is an indication of a shorted horizontal ouptut transitor and bad flyback transformer
Mar 14, 2009 | RCA HD52W58 52" TV
Going to an ant on my TV
NO!!!!!!! You are HD Ready if your TV is HD if not then you will need converter box to recieve channels from a antenna,.
Dec 30, 2008 | Televison & Video
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
RCA Scenium
I had the problem myself with my Scenium, the TV has a prblom with the circuitry and only fix is through an authorized RCA repare facility. Hope its fixed for you soon, awesome tv.
Rate plz
Sep 15, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The picture on my RCA Scenium HDLP61W151 61 in - was completed black
unplug both the TV and the cable box for 2 minutes then replug them in. this will reset the micros in both units. if there is still no sound check your SAP setting make sure its off.
Feb 06, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
