Question about Refrigerators
LG GR 349SQF. The freezer only cools to 4degree c, and fridge to 8c. Even at the top setting. The fan is working well but I notice when I pulled cover off freezer area to inspect that the freezing element only gets cold or ice on it at the top section and the rest of the aluminium element that snakes downward is warm. Could this be low gas or blockadge? Also the fan at rear bottom of fridge is working and all the light buttons etc, all seem to be fine.
    Top Expert:
  • Refrigerators Master
  • 25,751 Answers
Probably needs a refrigeration engineer to re gas it or fix a leak.
Posted on Jun 20, 2017
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore coldspot model:10653502330 does not stay cold
hi thanks for the question i would check the back by the compressor make sure its clean . then check the fan in freezer to see if it works then see if the frost built up in freezer you could have just a dirty condenser thanks the appliance doc
Posted on Sep 27, 2008
SOURCE: top of fridge warm but bottom freezer working ok
there is also a fan in the freezer compartment which if broken will cause this problem. you need to check that both fans are working. please refer to other fridge posts here re repairing/ replacing the freezer fan- there is a document here which shows you exactly what you need to do. important thing is to switch off the appliance first and leave the freezer door open for about 20 minutes before attempting to remove the back cover ie let it warm up first, so that you don't break any of the panels.
Posted on Jan 05, 2009
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 18 Answers
SOURCE: Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
Posted on May 29, 2009
I have a LG mod GR-S462GCA fridge not cooling turn it off for a day and works well for a couple of days then starts to not cool
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT
Jan 17, 2015 | LG Refrigerators
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Refrigerators
My freezer is working perfectly but the fridge is not
The channel in the back were the cool air comes down from the freezer to the fridge may be iced up. Try defrosting the fridge/freezer for much longer than usual, all day if necessary.
Aug 30, 2009 | LG LRTP1231W Top Freezer Refrigerator
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
Could be a wire short,bad defrost heater, or comp. pulling too many amps which is between 2 and 6 or higher being bad. I would say the main problem is you purchased a LG fridge which is a poorly made fridge,sorry.
Mar 30, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
