InterAct Accessories InterAct Racing Wheel V3 Wheel And Pedals Set Logo
Posted on Mar 11, 2011
How to set up v3 advanced fx racing wheel for ps2
1helpful
I bought a used V3 racing wheel for my PS2, and I can not get it to work. Everytime I hook it up it tells me that I need to plug in a dualshock 2 analog controller. I would really like to be able to use my...
Are you sure the game you're using the racing wheel for is compatible with it? Not all games are supported, so that could be why that message is popping up.
Logitech G25 racing wheel controls dead / No sound
A consealed plug under the wheel console had pulled out
The sound lead had been disconnected to allow another device to be fitted
3helpful
Ps2 steering wheel
My Interact V3 Steering Wheel does not work on my PS2. What do I need to do to make it work?
5helpful
V3 fx steering wheel for PS2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Here are all of the instructions enjoy. clip_image001.gif
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. ( 3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the MODE LED indicator will start blinking and two "beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button that corresponds to the setting you desire. Directional pad UP and SELECT will give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you medium sensitivity. Directional pad DOWN and SELECT will give you low sensitivity.
3. After selecting one of the above sensitivity options you will hear 2 "beeps" letting you know that the wheel has been programmed. For Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your wheel.
1helpful
V3 racing wheel
I have the same Interact V3 Wheel and with Win XP I can't use the drivers. Just configure it as a standard 2-axes 4-button wheel. It works great
11helpful
3answers
Manual and Troubleshooting resource for InterAct V3 Racing Wheel - Sony PS2
Hi there 78 Racer, Press SET button the LED light will start to blink and beep once. Press the square button on the right hand side of the wheel. This will set it to Digital and pressing the circle will change it back to Analogu. The LED will stop blinking and a double beep sound indicates it's been set - that's it
Thrustmaster challenge racing wheel for ps2
well i think the usb id for the pc so you cam play racing games of pc ok!
Question about the Interact Force Feedback FX Racing Wheel
This wheel has a 15 pin gameport connector. The pedals are connected to the wheel with a (ps2? s-video?) doo-hickey. There is also a brick for power. Mine got wet and rotted the inside of the round part of the plug.
1helpful
Ps2
You have set to the game your playing in the opitions menu and select the configuration to steering wheel. Some games you can't use this opition.
4answers
Software for V3 Racing Wheel
Easiest solution seems to be. Throw it away. buy something newer.... I gave up trying to locate drivers
Top InterAct Accessories Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you an InterAct Accessories Video Game Console and Game Expert? Answer questions, earn points and help others
