Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
GE Profile Artica Model # PSS25NGMA BB The freezer temp is rising +18F and the temp is set at -6F.
2 Suggested Answers
  • 10865 Answers
SOURCE: ge profile artica not cooling
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Posted on Aug 16, 2009
    My ge artica model number pss25ngma the refer part freezes evertyhing. I have adjusted the temp but it goes back to 32 waht can I do?
    check the evaporator fan; listen to see if it is running check the baffles between the freezer and, the refrigerator box for air flow. Check the control knob to see if it is turning the cold control shaft. If these are not the problem: replace the cold control
    Mar 17, 2010 | GE Profile Arctica Stainless Steel Top...
    GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
    use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
    Aug 18, 2009 | GE Refrigerators
    Ge profile artica not cooling
    • The compressor
    • The Thermostat
    • The defrost timer
    Aug 16, 2009 | GE GSH25JFR Side by Side Refrigerator
    Frig gets too cold freezer works good
    I had the same problem. I have the side by side Profile Artica. The problem was a broken damper. It allows the cold air in from the freezer side. With it broken, there was a steady flow of freezer air coming into the frig side. It was easy to fix. I ordered the part (damper/fan assemble) for around $100. While searching for a solution, it seems that this is a common problem. Unfortunately, I received a wide range of incorrect solutions to the problem which could have cost me a lot of money. I hope this helps!
    Jun 19, 2009 | GE Profile PFS22 33" Artica French Door...
    Freezer never cools consistently and compressor never goes off
    I am posting this for the sake of curiosity. I want to know if it gets resolved.
    Jun 18, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
    GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
    Use the damper control to direct less air into the refrig compartment from freezer
    Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
    Does not stop cooling down
    Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
    Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
    May 03, 2008 | GE Profile¿ Arctica® Energy...
    Refrigerators Logo
    162 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Gene Tuck
