Question about Cameras
Xd cards unable to be read by computer - Cameras
    Guru:
  • 196 Answers
Some computers need to have a firmware update to read the XD cards others cant get the update and just plain wont work, it just depends on the computer and if the manufacture sprung for the updated chip. Older chips you cant update newer chips you can put in the new driver or firmware. check th manufacture site to see if this is the case. With dell laptops this is the case, of some can updae and some cant.
Posted on Mar 11, 2011
Mi laptop Dell Inspiron 11 z no reconoce la tarjeta SD
  • Maria, the reader only reads the cards listed below. try another card to see if it reads another. If you open My Computer does the system see the card from that area?
  • The 7-in-1 Media Card Reader reads the following memory cards:
    • Secure Digital (SD)
    • MultiMediaCard (MMC)
    • Memory Stick (MS)
    • Memory Stick PRO (MS-PRO)
    • xD-Picture Card (xD)
    • MMC+
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 02, 2014 | Dell Inspiron 11Z Laptop Computer (Intel...
Tip
Computer Cannot read my SD Card
STOP SD MEMORY CARDS ARE NOT ALL THE SAME !This is a very common issue as of late because of the fairly recent addition to the market place with the "HC" and "XD" Cards. I have found most computer older than 2008 wont read HC and XD cards however I'm sure there are USB card readers that can fill this gap available at your local pc shop. Please look Carefully at these different formats Standard SD: 1 MB to 4 GB readable by almost all computers most often up to 2GB rarely up to 4GB 6468175.jpg
SDHC: 4 GB to 32 GB Most older Computers Cannot read the the HC format, good however for NEWER devices such as camera's, video cameras and recent phones (my cannon powershot S80 will NOT read HC format, nor will my 2007 laptop.)
SDXC: 32 GB to 2 TiB same limitations as above, Great cards for Digital Video Camera though!
here is a wikipedia note "Changes to the interface of the established format have made some older devices designed for standard SD cards (≤4 GB) unable to handle newer formats such as SDHC (≥4 GB). All SD cards have the same physical shape, which causes confusion for many consumers"
So.. in closing MAKE SURE your device supports HC and or XC before your purchase one! Also be aware that most of these cards have a lock switch on them to write protect the data, located on the side of the card. It MUST be in the Unlocked position to operate normally. Hope this helps someone out there. please use the thumbs up if it clears up anything for you! Gurvy
on Aug 31, 2010 | Computers & Internet
I have a fe-200 olympus camera, after i transferred the images, the memory card say write protect, the memory card has no switch on the side, and now i cant take any pictures happened to both of my memory...
Your camera uses xD memory cards, and they never have a physical locking switch.
Your problem is most likely due to having used the xD card in an external card reader. The host pc sometimes sets the xD card as a "read only" drive. If so you must go back to the host pc and connect the xD card again. If using Windows then click on My Computer and highlight the xD card. Right click and select Properties from the device menu. Uncheck the box marked Read Only.
If that's not the cause of your problem then try re-formatting the card in your camera. NEVER re-format it using a computer.
If those options both fail, try another xD card which is known to be fully functional in your camera. This will determine whether the camera or the card is at fault. The camera is too old to merit the cost of a professional repair, and there's nothing more to be done with a faulty xD card, so replace whichever item is faulty.
You may also wish to consult the user manual for your model which you can download for free from Olympus in .pdf format.
I hope that I've been of assistance, please take a moment to rate my speedy and free answer.
Mar 08, 2011 | Olympus FE-230 Digital Camera
OLYMPUS XD Card - CLEAN or FORMAT - and not reading in computer
Your 2gb xd card would be of the "M" or "H" designation, which is a new type of card which is not always compatible with many cameras and card readers. If the other cards that work are not H or M cards, that is most likely the problem
Jun 24, 2009 | Fuji FinePix A340 Digital Camera
Format-less
put it back in the computer and try to format it there.
Jun 14, 2009 | Olympus Camedia C-350 Digital Camera
Olympus xd card formatting problems.
If you like the camera and XD cards then I would use the USB cable to download the photos from the camera. When you plug the USB cale into the camera and then into the computer, the computer should recognize the camera and set it up as another disk drive. Copy or move the pictures from the card to your Photo location. Use the "Safely Remove Hardware" icon in the system tray to disconnect the camera and your done. The camera can format the XD card and the computer can read it through the camera.
May 28, 2009 | Olympus FE-340 Digital Camera
Xd downloads for the fuji S7000
May sound naive to you, but sometimes, particularly in XD card, when it is not being read by a card reader or camera, just try to wipe it's Copper plates firmly with your thumb and try again. Repeat the process. It happened with me and i tried it accidently once, and it worked, and it has worked many times. Don't scratch the copper plates, just wipe with ur thumb. Hope it works for you too. Good Luck.
Oct 14, 2008 | Fuji FinePix S7000 Digital Camera
Screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
Mar 07, 2008 | Fuji FinePix A330 Digital Camera
No Image
Please read these/the 2 posts that I posted prior for a similar XD mem card problem, as I firmly believe you are "formatting" your mem card improperly using your home computer instead of "formatting" the card on your camera.
Also the XD type card & size are very important also!!
What you will have to do is read and download the photos you have on that XD card using the same "card reader" you used before and then properly "re-format" that card in your "CAMERA ONLY". This should solve your XD card problems.
PRIOR POSTS:
Kristina,
Not knowing what model Olympus camera you have, or how old it is - your new memory card "format" problem is one of 3 possibilities.
1st - If you have an older Olympus camera more then 4-5 years old the newer M & H series type cards over 256mb will probably not work in your older camera, as by the camera's internal firmware chip design of the camera itself. Some cameras were upgradeable some weren't as to the internal firmware chip as well as available software drivers depending on which computer OS system you were using ie: (WIN98SE, WIN2000, etc). Has to do with the memory card read/write chip speed as well, and also has to do with the physical storage size of the card itself. Some digital cameras were MAXED OUT at 512mb cards, some as low as 256mb. A 2gb card simple won't work in that/your camera in that case.
If you read the camera's user manual it will possibly tell you this, or else go online to www.olympusamerica.com and use this link:
View which cameras are compatible
Select camera model series and scroll down the model # and research the max card size & type you can use (3 basic XD card speed types available - regular XD - M type - H type).
If you are using the wrong type & size card you will need to return that card (if you can) and get the right XD size & type for your camera.
2nd - You should always FORMAT (same as ERASE ALL and FORMAT modes on most Olympus cameras) the new card, or any XD card for that matter in your camera itself. NOT THE HOME COMPUTER!!! The 2 format procedures are not the same!!
If you are re-shooting (re-using) the same XD card over and over again and then downloading the JPEG pix directly to the computer using a USB interface cable there usually is no need to re-format the card again as long as the XD card stays the camera and is not downloaded into a home computer via a "card reader". If you do the latter "card reader" then I would advise doing a card re-format in the camera again just to be safe!!
And lastly - If your home computer recognizes the XD card via a good "card reader" (do not FORMAT the XD card here btw, as you are just checking the card out to see it is GOOD is all), but the camera will not then that is a good sign your camera is OK, but it's just the wrong type & size XD card.
Hope this helps solve your camera XD problem not knowing which model you have.
Best regards,
Frank
AND:
Follow up to previous post:
I didn't have the time to access the exact link below to check on your specific 2004 model year camera because I missed the Fuji camera model part, as I'm brand new to this site - so please forgive my previous oversight here.
I was right though in my initial posted assumption that you bought the wrong XD memory card based on your Fuji FinePix A330 Digital Camera - as to it's older model year - in that your camera is limited to a 512mb memory card.
Make sure you buy the 512mb standard card if you still can find them. Otherwise check with Fuji Corp to make sure the M type card (faster read/write chip) will work in your specific model. The M type cards work just fine in my Olympus C-740 even though it was told to me they wouldn't work at all, but each digital camera is slightly different as to it's internal firmware (BIOS) chip.
See the following camera info for your specific model at the link below under Storage Media:
Steves Digicams - Fujifilm FinePix A330 - User Review
I hope this now clears up any prior confusion from the previous post.
Best regards,
Frank
Feb 06, 2008 | Fuji FinePix A330 Digital Camera
Memory card problem
Hi I suspect this is due to the printer being unable to read this size of memory card, as i have the same problem, where as it will read a 128mb card but not gb !
Feb 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
